Image Artifacts with Bitmap and ImgTag UI controls. Why?
By Hernan Rodenstein · 2016-11-16
Hello guys,
I'm writing the help for a script I'm doing and I need to display a screen capture of the script's UI on the help rololut.
The problem is the image is not displaying accurately. It has some little artifacts.
Please see the image below:
The 3 images are from the same source file.
The 2 images on the left are: - top: Bitmap UI control - bottom: ImgTag UI control
Both have little artifacts.
The image on the right is displayed on a Virtual Frame Buffer and it is correct.
The problem seems to be related to image compression or something like that I guess...
Does anybody have a clue about why are the images not displaying well?
Thanks in advanced!
Hernan Rodenstein
I did not use DotNet before...
Can you please tell me how to implement it?
Here's the code I used:
global testRollout
global testFilename = "test.jpg"
global testBmp = openBitMap(getfilenamepath (getThisScriptFilename())+testFilename)
rollout testRollout "Test UI Image Display"
	label lb1 "BITMAP" align:#left offset:[0,6]
	bitmap bmp1 fileName:testFilename width:179 height:270 align:#left offset:[-2,0]
	label lb2 "IMGTAG" align:#left offset:[0,16]
	imgTag bmp2 "" bitmap:testBmp style:#bmp_center width:179 height:270 align:#left offset:[0,0]
try (destroyDialog testRollout) catch()
createDialog testRollout 450 640
display testBmp caption:"test"
I attach the image "test.jpg".
fajar
are you already try use net pictureBox ?
please upload img sample that you use
