I've created a rollout script that can collect bones then create an IK/FK Blend system around the bones and has an undo button to delete all created objects.
The Undo button works fine... until I select all of the FK control objects and rotate them. There fine if I rotate them 1 by 1 but if I rotate all, it forgets there in an array and max gets upset =( It returns this error message:
-- Error occurred in UndoButton.pressed(); filename: C:\Users\Ben Styles\Desktop\IKFKScript\maxscriptIKFK2edited4.ms; position: 15865; line: 427
-- Frame:
>> MAXScript Rollout Handler Exception:
-- Unknown system exception <<delete FKControlObject << line 427
Then if I delete the rest of the object remaining in the scene, max crashes. It does this 100% of the time.
In the create button block I create all the objects and add them to there own arrays, such as IKBones, FKBones and FKControlObjects. On the Undo Button block I delete those arrays along with the reference I set for the IKGoal and IKControlObject.
Here is a cut down version of the script:
Full script can be downloaded Here:
http://www.megafileupload.com/en/file/501703/IKFKBlendSetupCreator-ms.ht…
Sorry if it's messy or hard to read.
--IK FK Setup Script 1.0 by Ben Styles
--Creates an IK FK blend setup around set bones.
--Designed for 3ds max 2014
--Email: Benstyles_999@hotmail.co.uk
rollout IKFKBoneSetupTool "Create Ik / FK Setup"
--Variables
local SortedBoneCollectionList=#()
local IKBoneColor = color 255 0 0
local FKBoneColor = color 0 255 0
local IKBone=#()
local FKBone=#()
local FKControlObject=#()
local IKGoal
local IKControlObject
local IKXformModifier= XForm()
local FKXformModifier= XForm()
on Create Pressed do
IKBone=#()
FKBone=#()
FKControlObject=#()
IKGoal=undefined
IKControlObject=undefined
if SortedBoneCollectionList.count<3 then
messagebox( "Needs more then 2 bones.")
--Loop Through Bone Collection
for i=1 to SortedBoneCollectionList.count do
--Create IK Bones
append IKBone (copy SortedBoneCollectionList[i])
if i < 10 then BoneName=SortedBoneCollectionList[i].name as string+"IK0"+i as string
else BoneName=SortedBoneCollectionList[i].name as string+"IK"+i as string
IKBone[i].name=BoneName
IKBone[i].width= IKBoneSize.value
IKBone[i].height=IKBoneSize.value
IKBone[i].wirecolor=IKBoneColor
IKBone[i].ShowLinksOnly = SortedBoneCollectionList[i].showlinksOnly
IKBone[i].ShowLinks = SortedBoneCollectionList[i].showlinks
--Parent IK Bones
if i > 1 do IKBone[i].parent=IKBone[i-1]
--Create FK Bones
append FKBone(copy SortedBoneCollectionList[i])
if i < 10 then BoneName=SortedBoneCollectionList[i].name as string+"FK0"+i as string
else BoneName=SortedBoneCollectionList[i].name as string+"FK"+i as string
FKBone[i].name=BoneName
FKBone[i].width= FKBoneSize.value
FKBone[i].height=FKBoneSize.value
FKBone[i].wirecolor=FKBoneColor
FKBone[i].ShowLinksOnly = SortedBoneCollectionList[i].showlinksOnly
FKBone[i].ShowLinks = SortedBoneCollectionList[i].showlinks
--Parent FK Bones
if i > 1 do FKBone[i].parent=FKBone[i-1]
--Create FK Control Objects
FKControlObjectName=SortedBoneCollectionList[i].name as string+"FK_Control_Object"+i as string
if i != 1 and i!=SortedBoneCollectionList.count then
append FKControlObject(CreateCircleControlObject FKControlObjectName FKBoneColor FKControlObjectRadius.value FKControlObjectThickness.value EnableRenderInViewportFK.checked)
append FKControlObject(CreateAxialControlObject FKControlObjectName FKBoneColor FKControlObjectRadius.value FKControlObjectThickness.value EnableRenderInViewportFK.checked)
FKControlObject[i].transform=SortedBoneCollectionList[i].transform
--Parent FK Control Objects
if i > 1 do FKControlObject[i].parent=FKControlObject[i-1]
if i == SortedBoneCollectionList.count do
--Create IK Goal
IKGoal = IKSys.ikChain IKBone[1] IKBone[IKBone.count] "IKHISolver"
--Create IK Control Object
IKControlObject = (CreateAxialControlObject "IK Control Object" IKBoneColor IKControlObjectRadius.value IKControlObjectThickness.value EnableRenderInViewportIK.checked)
IKControlObject.transform=IKBone[IKBone.count] .transform
IKGoal.parent=IKControlObject
--Create IK/FK Custom Attribute Spinner on First FK Control Object
if i==1 do
addModifier FKControlObject[i] FKXformModifier
AddIKFKAttribute FKControlObject[i]
--Setup Orientation Constraints
OrientationConstrain SortedBoneCollectionList[i] IKBone[i] 50
OrientationConstrain SortedBoneCollectionList[i] FKBone[i] 50
OrientationConstrain FKBone[i] FKControlObject[i] 100
--Wire IK/FK Attribute Spinner to Bone Orientation Weights
paramWire.connect FKControlObject[1].modifiers[#Attribute_Holder].IKFKcontrols[#iKfK] SortedBoneCollectionList[i].rotation.controller[#Orientation_Weight_0] "100-iKfK"
paramWire.connect FKControlObject[1].modifiers[#Attribute_Holder].IKFKcontrols[#iKfK] SortedBoneCollectionList[i].rotation.controller[#Orientation_Weight_1] "iKfK"
--Wire Bone and Control Object Visibility
if VisibilityCheckBox.checked==true do
FKBone[i].visibility = bezier_float()
IKBone[i].visibility = bezier_float()
FKControlObject[i].visibility = bezier_float()
paramWire.connect FKControlObject[1].modifiers[#Attribute_Holder].IKFKcontrols[#iKfK] FKBone[i][#Visibility] "iKfK"
paramWire.connect FKControlObject[1].modifiers[#Attribute_Holder].IKFKcontrols[#iKfK] FKControlObject[i][#Visibility] "iKfK"
paramWire.connect FKControlObject[1].modifiers[#Attribute_Holder].IKFKcontrols[#iKfK] IKBone[i][#Visibility] "100-iKfK"
--Add Xform Modifier to IK/FK Bones
addModifier IKBone[i] IKXformModifier
addModifier FKBone[i] FKXformModifier
--Copy IK/FK Attribute Modifier to FK Control Objects
AttributeModifier=FKControlObject[1].modifiers [1] -- Instance of IK/FK Attribute
addModifier IKControlObject IKXformModifier
addModifier IKControlObject AttributeModifier
for i=2 to FKControlObject.count do
addModifier FKControlObject[i] AttributeModifier
--OrientationConstrain IK Nub
OrientationConstrain IKBone[IKBone.count] IKControlObject 100
--Wire Xform Modifiers to IK/FK Attribute
if ScaleCheckBox.checked == true do
paramWire.connect FKControlObject[1].modifiers[#Attribute_Holder].IKFKcontrols[#iKfK] FKBone[1].modifiers[#XForm].Gizmo.controller[#Scale] "[iKfK/100,iKfK/100,iKfK/100]"
paramWire.connect FKControlObject[1].modifiers[#Attribute_Holder].IKFKcontrols[#iKfK] IKBone[1].modifiers[#XForm].Gizmo.controller[#Scale] "[(100-iKfK)/100,(100-iKfK)/100,(100-iKfK)/100]"
--Lock Transforms
setTransformLockFlags IKGoal #all
setTransformLockFlags IKControlObject #{7..9}
on UndoButton pressed do
for i=1 to IKBone.count do delete IKBone[i]
for i=1 to FKBone.count do delete FKBone[i]
for i=1 to FKControlObject.count do delete FKControlObject[i]
if IKGoal != undefined do delete IKGoal
if IKControlObject !=undefined do (delete IKControlObject)
delete IKBone
delete FKBone
delete IKGoal
SortedBoneCollectionList[i].rotation.controller = Euler_XYZ()
createDialog IKFKBoneSetupTool width:300 height:400Array Variables are first declared inside the rollout block at line 9.
Objects are created in the CreateButton Pressed block at line 250.
Objects are deleted in the UndoButton Pressed block at line 404.
If anyone could please explain why and/or fix this I will be very grateful. Thanks for listening!
Maniczombie.
