IFL's broken?
By JokerMartini · 2016-09-12
Try this snippet of code, run these in this order and you'll noticed the IFL will not update for the second sequence. It will still attempt to load 30 images even though there are only 5.
capture_viewport filepath 0 30 -- Run first
capture_viewport filepath 0 5 -- Run second
Here is all the code..
fn capture_viewport filepath start end =
	local dir = getFilenamePath filepath
	local filename = getFilenameFile filepath
	local filefilter = pathconfig.appendpath dir filename
	local files = getFiles (filefilter + "*" + (getFilenameType filepath))
	-- delete any pre existing files
	for f in files do deleteFile f
	-- capture scene
	view_size = getViewSize()
	temp_bmp = bitmap view_size.x view_size.y gamma:1.0 filename:filepath
	for t = start to end do
		sliderTime = t
		dib = gw.getViewportDib()
		pasteBitmap dib temp_bmp (box2 0 0 view_size.x view_size.y) [0,0]
		b = save temp_bmp frame:t
		close temp_bmp
	-- open in ram player
	local theIfl = pathconfig.appendpath dir (filename + ".ifl")
	local file_handle = createFile theIfl
	for f in files do format "%\n" (filenameFromPath f) to:file_handle
	close file_handle
	RAMPlayer (theIfl) ""
filepath = (getDir #preview)+"/test.jpg"
-- capture_viewport filepath 0 5 -- Run second
pixamoon
this is some way around
local theIfl = pathconfig.appendpath dir (filename + "_" + start as string + "_" + end as string + "_" + ".ifl")
I tried also delete ifl first and save with
(dotnetClass "System.IO.File").WriteAllLines theIfl files
but still ramplayer tries to loads previous ifl file
only saving with other filename helps for now
It looks like RAMPlayer keeps ifl list in memory if ifl file name is the same as previous
If you run it with (0-30 and 0-5) you will get error - than changing to (0-5 and 0-5) still show the same error
Reply to pixamoon
pixamoon
oki, so one more way around is to use temp Ifl file:
	local tempIfl = pathconfig.appendpath dir (filename + timestamp() as string + ".ifl")
	copyfile theIfl tempIfl
	RAMPlayer (tempIfl) ""
	deletefile tempIfl
and whole code:
	-- capture scene
		sliderTime = t
		close temp_bmp
	close file_handle
	--- new by pixamoon
	deletefile tempIfl
	--- end new
capture_viewport filepath 0 5 -- Run secondw
basically Ramplayer needs to be started with new ifl filename eatch time - otherwise uses old list
hope this helps
