Icons disappear
By Andrey · 2020-04-01
Hello
There was a problem with the icons when creating the interface.
I add icons by type (←) and everything works, but after restarting 3ds Msx, the icons fly off.
Is there a solution to the problem?
Comments (7)
Andrey
Thank you for the answers, they helped me. The problem is resolved.
Icons turn out small, is it possible to increase their size?
Reply to miauu
Andrey
I do not understand
I use the standard 3D max button on which I use "\ x2199"
The icon turns out to be small, I would like to enlarge it. Is it possible to achieve this.
I can’t download the utility.
Is there a good example of how this works?
Thanks.
You copy-paste icons in your code or you type this "x\2798"?
Vojtech Cada
When saving the file, choose a format that supports unicode characters:
