Hallo.
The script writen below creates layers by a base name via sub-names defined in script. To create layers at least one checkbox should be checked to enter a word in edittext line.I add a function to the script to block edittext line until a checkbox was checked but only last checkbox doing what I need.
I need to your help to fix this issue.
--- LayerCreator 1.0 ---
--- Globals for script ---
global lyrDefNames
global lyrNames
--- Define globals---
lyrDefNames=#()
lyrNames=#()
---The function to create layers---
fn crtNewLayer =
for n = 1 to lyrNames.count do
i= n
x= lyrNames
y= layermanager.getlayerfromname x [i]
z= layermanager.newlayerfromname x [i]
if y != undefined then
z
---Rollout for interface of script---
rollout LayerCreator "LayerCreator 1.0" width:280 height:208
GroupBox Layers "Select Layers for Scene Objects" pos:[8,40] width:264 height:112
checkbox lyrCameras "Cameras" pos:[144,88] width:120 height:24
checkbox lyrController "Controller Objects" pos:[16,88] width:120 height:24
checkbox lyrHiden "Hiden Objects" pos:[16,120] width:120 height:24
checkbox lyrLights "Light Objects" pos:[144,56] width:120 height:24
checkbox lyrMesh "Mesh Objects" pos:[16,56] width:120 height:24
checkbox lyrParticles "Particles" pos:[144,120] width:120 height:24
edittext lyrBsName " Base Name of Layers" pos:[13,7] width:254 height:17 enabled:false
button crtLayers "Create New Layers" pos:[8,160] width:264 height:37 enabled:true toolTip:""
--- The function to enable edittext because at least one checkbox should be checked before enter a word in edittext line ----
fn txtEnbl=
cb=#( lyrCameras.triState, lyrController.triState, lyrHiden.triState, lyrLights.triState, lyrMesh.triState, lyrParticles.triState)
for i= 1 to cb.count collect
if cb [i] != 1 then
lyrBsName.enabled= false
if cb [i] == 1 then
lyrBsName.enabled= true
---Adding a string by each checkbos to the global lyrDefNames ----
on lyrCameras changed theState do
txtEnbl ()
if lyrCameras.checked == true then
objCameras= "_Cameras"
append lyrDefNames objCameras
lyrDefNames [1] = undefined
on lyrController changed theState do
txtEnbl ()
if lyrController.checked == true then
objController= "_Controller"
append lyrDefNames objController
lyrDefNames [2] = undefined
on lyrHiden changed theState do
txtEnbl ()
if lyrHiden.checked == true then
objHiden= "_Hiden"
append lyrDefNames objHiden
lyrDefNames [4] = undefined
on lyrLights changed theState do
txtEnbl ()
if lyrLights.checked == true then
objLights= "_Lights"
append lyrDefNames objLights
lyrDefNames [5] = undefined
on lyrMesh changed theState do
txtEnbl ()
if lyrMesh.checked == true then
objMesh= "_Mesh"
append lyrDefNames objMesh
lyrDefNames [3] = undefined
on lyrParticles changed theState do
txtEnbl ()
if lyrParticles.checked == true then
objParticles= "_Particles"
append lyrDefNames objParticles
lyrDefNames [6] = undefined
--- Adding a sting when text entered to the text line ---
on lyrBsName entered txt do
bsName= lyrBsName.text as string
cmbNames=
if bsName != "" then
if lyrDefNames != undefined then
for i= 1 to lyrDefNames.count collect
append lyrNames (bsName + lyrDefNames [i])
if bsName =="" then
lyrNames= #()
--- When button pressed creating layers---
on crtLayers pressed do
crtNewLayer ()
createdialog LayerCreator
BTW
@Deman3D
I not tested this tool and I leave it to you to check that.
Cheers!
lyrDefNames=#()
I arrange the code a little, check it, hope it helps
I arranged a bit more ei. I clean up the mess
Just joking...
Anyway it's more convinient this way. You can see all names in the list before layers creation
try (DestroyDialog ::LayerCreator) catch()
rollout LayerCreator "LayerCreator v1.0"
local prxList = #("_Cameras","_Controller","_Hidden","_Lights","_Meshes","_Particles","_Helpers","_Proxies")
fn createLayer layname = (layermanager.newlayerfromname layname)
fn isLayerExist layname = (layermanager.getlayerfromname layname != null)
fn collectPrefixes arr:prxList roll:LayerCreator = (for c = 4 to 11 where roll.controls[c].checked collect prxList[c-3])
label titles "Base Name of Layers: Layer Prefix:" pos:[5,5]
edittext lyrBsName "" pos:[1,20] fieldwidth:200 height:17 enabled:off
multilistbox layNames "" pos:[5,40] width:200 height:8
checkbox lyrCameras "Cameras" pos:[210,20]
checkbox lyrController "Controllers" pos:[210,40]
checkbox lyrHidden "Hidden Objs" pos:[210,60]
checkbox lyrLights "Lights" pos:[210,80]
checkbox lyrMesh "Meshes" pos:[210,100]
checkbox lyrParticles "Particles" pos:[210,120]
checkbox lyrHelpers "Helpers" pos:[210,140]
checkbox lyrProxy "Proxies" pos:[210,160]
button clearSel "Clear Selected" pos:[5,152] width:100
button clearAll "Clear All" pos:[105,152] width:100
button crtLayers "Create New Layers From List" pos:[5,175] width:200 height:30
button openLM "Open LM" pos:[210,175] width:75 height:30 tooltip:"Open Layer Manager"
fn enableTextBox roll:LayerCreator tb:lyrBsName =
local state = off
for c = 4 to 11 where roll.controls[c].checked do exit with state = on
tb.enabled = state ; if state then setFocus tb else tb.text = ""
on openLM pressed do (if not (LayerManager.isDialogOpen()) do LayerManager.editLayerByName "")
on clearAll pressed do layNames.items = #()
on clearSel pressed do
if not (layNames.selection).isEmpty do
local idxs = layNames.selection as array
local items = layNames.items
for i = idxs.count to 1 by -1 do deleteItem items idxs[i]
layNames.items = items
on lyrCameras changed state do enableTextBox()
on lyrController changed state do enableTextBox()
on lyrHidden changed state do enableTextBox()
on lyrLights changed state do enableTextBox()
on lyrMesh changed state do enableTextBox()
on lyrParticles changed state do enableTextBox()
on lyrHelpers changed state do enableTextBox()
on lyrProxy changed state do enableTextBox()
on lyrBsName entered txt do if txt != "" do
local prxArr = collectPrefixes(), listItems = layNames.items
local newnames = for p in prxArr collect
if findItem listItems (name = txt+p) == 0 then name else dontCollect
if newnames.count != 0 do layNames.items = join newnames listItems
lyrBsName.text = ""
on crtLayers pressed do if (listItems = layNames.items).count > 0 do
local toDelete = #()
for i = 1 to listItems.count do (if isLayerExist listItems[i] then append toDelete[i] else createLayer listItems[i])
if toDelete.count > 0 do
for i = toDelete.count to 1 by -1 do deleteItem listItems i
layNames.items = listItems
createdialog LayerCreator 290 208 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
Thanks.
Thank you very much for your script you created to me. Yes your codes are much better than mine and properly work but as you can understand I am trying to learn maxscript to support my workflow on 3ds max. I will examine your script detailed and they are very precious to me while I try to learn something more.
Regards.
My pleasure. If you not understand something in my code just ask, but before that try to find answers in maxscript help document. It's better that way if you want to learn and understand why or how things works. We all started that way.
If you not already watched this video training just take a look http://vimeo.com/album/1514565
Your script codes are very helpful to understand how I should create a loop for my purpose.
Thank you very much.
