I need a really easy custom 3DS Max script written for me, can anyone help?
By Jez · 2023-09-06
I need a script written and I'm looking for some help from you experts out there (I'm sure it'll take you guys literally seconds to write this one :) ).
Here's the design;
a) I have around 100 folders, and in each folder there a varying number of splines between 2 and 10 I'd say in each one.
b) I have a Master_Spline that's to be used as the master path for sweeping each those splines that are in each of those 100 Folders.
Here's what I want the script to do.
1) The Script is to go through each of those folders and for each of those splines, create a Sweep Object for it - using the spline as its profile and the Master_Spline as its Path.
2) Then, a Smooth modifier to be then added on top of that Sweep modifier.​
3) That Swept Object that has just been created is to be placed in the same folder that was being worked through and the name of that swept object is to be a concatenation of the name of the Sweep Profile used along with the Suffix "_Skt".
Note: I want this set up so that if I decide to change the Master Spline after this script has been run, then I'd also want the path of all of those Swept Objects to also change as well (in other words, of course, I'm wanting Instances here).
And that's it, that's the script I need!
(well, for now )
Can anyone please help? I'll happily pay for your time.
Many thanks.
You can email me at miau_u@yahoo.com
Reply to miauu
Jez
Hi Miau,
Sent you an email to your yahoo.com email address.
Many thanks.
