I was given ....................
Macroscript PolyAttachMultiple
Category: "TJ_Modeling"
Tooltip: "Poly Attach Multiple"
undo on
selectionArray = selection as array;
for obj in selectionArray do
convertTo obj PolyMeshObject
try
for i = 1 to (selectionArray.count - 1) do
polyOp.attach selectionArray[selectionArray.count] selectionArray[i];
catch(print "you have attempted to attach incompatible objects")
I want to install this to my 3ds max and i do not know how to. Anybody
Should i copy and paste it to RUN MAXSCRIPT (which i already tried)
Please let me know. I know hos to install script in MZP file, But the above information, I do not know what to do with it.
I personally would not recommend you to use this script. It does not check whether selected objects can be converted to PolyMesh, instead it makes unnecessary check (post facto) for attach event and then trow error message. If the objects were successfully converted, they not need attach check. But if can convert to poly must be catched at the beginning.
Just drag and drop your text file "PolyAttachMultiple.mcr" on Max screen., then you'll be able to find your script in customize menu in "TJ_Modeling" category.
