How to store object keys?!
By JokerMartini · 2010-09-02
I've wrote up this basic script that takes a selection of objects and I want it to be able to take each objects individual keys and flip them on the x-axis. I do this by running a function that multiplies the existing keys on the object by -1.
Problems
-It's bugging out when I hit the apply button of the script. It's not applying the function to each key properly when applied.
-I'm not sure if the storing of the objects pre-existing keys is where the problem is.
Help would be appreciated.
JokerMartini
Comments (7)
JokerMartini
I'm not sure why there is a pick object button?
I'm trying to avoid having a pick button. I just want each object in the select to reference itself for its keys.
That way users to can select an array of objects with different animation on them and flip them.
Reply to JokerMartini
Hi Martin, this was in case you copy keys from an object to multiple objects. I just trying to figure out why you use $ sign on multiple objects. Now, reading your last post, I think so you need only the function that I post before --
-- EDIT: simplified function version (strip 2 arguments):
function flipPositionKeys axis =
    userSel = getCurrentSelection ()
    for obj in userSel do
        userKeys = obj.position.controller[axis].controller.keys
        if userKeys.count > 0 do
            for k in userKeys do k.value *= -1
-- Usage:
flipPositionKeys 1 -- X axis
flipPositionKeys 2 -- Y axis
flipPositionKeys 3 -- Z axis
JokerMartini
This does not work with a selection of objects, it only works with one object selected?
I've hit a mind block and can not solve it.
ObjKeys = undefined
rollout roAdjustAnimation "Animation Abjust"
    button btnApply "Apply" width:90 height:90 pos:[5,5]
--New Function
    function flipPositionKeys axisS axisD dir =
        ObjKeys = $.position.controller
        for i = 1 to userSel.count do
            s = userSel[i]
            if(ObjKeys[axisS].controller.keys.count >= 1) then
                userKeys = ObjKeys[axisS].controller.keys
                for k in userKeys do k.value *= dir
    on btnApply pressed do
		for Obj in selection do
        flipPositionKeys 1 1 -1
createDialog roAdjustAnimation 100 100
This
will works only on single selected. Maybe I miss the final goal as well... if the objects already animated, the next function will work on multiple selection. if you need to copy the keys from 1 object to multiple objects, just write separate function.
        userKeys = obj.position.controller[axisS].controller.keys
------------- EDIT --------------------
-- Ok, there you go working version...
	local srcObj
	pickButton pbtSource "Pick Object" width:90 height:40 pos:[6,6]
    button btnApply "Apply" width:90 height:40 pos:[6,46]
-- flip pos keys function
	function flipPositionKeys userSel axisS axisD dir =
		--userSel = getCurrentSelection ()
-- get pos keys function
	fn getPosKeys obj axis = (obj.position.controller[axis].controller.keys)
	on pbtSource picked obj do
		if isValidNode obj do srcObj = obj
		if userSel.count > 0 and isValidNode srcObj do
			userKeys = getPosKeys srcObj 1
			-- copy keys...
			for obj in userSel do (
				targetKeys = getPosKeys obj 1
				for key in userKeys do (
					appendKey targetKeys key
			-- flip keys...
			flipPositionKeys userSel 1 1 -1
Maybe appendKey() function is buged?... If to say the object has 2 keys #(1f, 30f), the function create 2 new keys at time 1 i.e. #(1f, 1f, 1f, 30f), totaly irregular result.
-- if replace this part of the code:
for k = 1 to userKeys.count do
	appendKey s.position.controller[axisD].controller.keys userKeys[k]
	s.position.controller[axisD].controller.keys[k].value *= dir
-- with this one:
-- it works fine
JokerMartini
(ObjKeys = undefined
ObjKeys = undefined
            s = userSel[i]
                userKeys = ObjKeys[axisS].controller.keys --holds keys from animated object's X-Position as a variable
                    deletekeys s.pos.track
                    deletekeys s.rotation.track
                    deletekeys s.scale.track
JokerMartini
Here is what I have so far. This is more recent than what the attached file is. I'm trying to store the keys in the variable ObjKeys but it is not working when its calling them up later to append the keys.
