like pic show
I make a gap and want to select the faces between two loop edges,
then use smooth.
How do I script it to convert looped edges selection to faces selection ?
Could someone help me, please ? \ . /
By ang · 2013-02-02
like pic show
then use smooth.
ur1na
pic show?Just use the slider. And @barigazy is right about it.
Like this Pic .What do you think?
solution
This function do the job
fn facesBetweenTwoLoopEdges obj = if isKindOf obj Editable_Poly do
local selEdges = (obj.selectedEdges as bitarray) as array
if selEdges.count != 0 do
local poGEF = polyop.getEdgeFaces, edgeFaces = #(), faces = #()
for ed in se do join edgeFaces (poGEF obj ed)
while edgeFaces.count != 0 do
idx = findItem edgeFaces edgeFaces[edgeFaces.count]
if idx != 0 and idx != edgeFaces.count do (append faces edgeFaces[edgeFaces.count] ; deleteItem edgeFaces idx)
deleteItem edgeFaces edgeFaces.count
obj.selectedfaces = faces
facesBetweenTwoLoopEdges $
Thanks a lot
Thank you sir, barigazy
When it evaluate, it has a warn in 8th line"for ed in se do join edgeFaces (poGEF obj ed)" .
Warn is " No "map" function for undefined ".
How do I do to solve it ?
for ed in selEdges do join edgeFaces (poGEF obj ed)
