hi
i am trying to figure-out how to run a external program with switch in command line.
for instance i can run (winrar e E:\gish.rar E:/tt) to extract the gish named archive in tt folder through windows command line.how can i do the same through maxscript?
i guess "DOSCommand","shelllaunch" or "HiddenDOSCommand" might help but all i can do is open the gish file by running (hiddendoscommand "E:\gish.rar")
please anybody help me out.
ps.the syntax for winrar is (WinRAR <command> -<switch1> -<switchN> <archive> <files...> <@listfiles...> <path_to_extract\> )
just supply your full string command
try this:
if the single quote-mark (') give error then s'd reformat the string, like:
well, in this case you can go even w/o quotes...
...because the path to the file end output path has not space (" ") char, but if they have (like "C:\Prgram Files") then s'd enclose this paths within quotes, but maybe you know this as this is commont for all command line calls.
thanks for the quick response. but still i cant make it work. all i get is "true" in listner. do you think it might be winrar that is the problem?
and maxscript is my first coding experience.even didnt run a program from commandline before.:-)so please be patient.
aha, ok
Well, make this test then.
[.] Put some valid rar file in
and name it
[.] Create a text file in
and name it
(the file extension bat is important)
[.] Open unrar.bat in Notepad
[.] Copy, paste and save this command to it:
[.] Run the .BAT file
Now the analyse.
If that not extract the "test.rar" then the console window s'd print some error message. The PAUSE is inside just to keep the console open, to can read whats wrong.
So, if there some message like 'WinRAR' is not recognizable command, then should use a full path to your WinRAR, i.e. if for example it installed in C:\Program Files (x86)\WinRAR\, then your dos command become:
Hope this help ;)
it is working nicely.first
first there was the error about non recognizable winrar. adding the full path solves this.
in the meantime i managed making a batch file from withing max by format command and running it by doscommand of maxscript .which works.but a bit silly. :-)
start winrar e E:\gish.rar E:/tt
thanks again.
ps.how i gonna put the full path in your 1st post? i mean into this
HiddenDOSCommand @"WinRAR E 'E:\gish.rar' 'E:\tt'" startpath:"c:\\"
s'd use \ to format the string
shortly:
notes:
then you put quotes (") inside string, formating them with backslash (\) made them compatible, this way the engine know that this sign is not mark the end of the string.
for example this command conteins quotes...
so if by some reason s'd be inserted in a string...
...then above will be valid.
note too, that single backslash (\) in the file paths also replaced with \\.
In the Mxs reference search for
to see all valid escape sequences ;)
everything is magically solved.
so putting double quotes resulting in a immature escape.
thanks for the walk-through.now i have a good idea about the "\"".
