Hi!
I got the following problem:
There are several equal objects in my scene, that i want to replace with the same object plus a light (so replace 1 object with 2 objects)
If I had to replace each object manually, that would take me days.
Is there an efficient way to say "replace every object from selection with a specific group of objects" in maxscript?
Thanks for answers ;)
Thank you so much!
I'm new to Max, didn't know that this possibility existed with Align & Distribute!
Worked out really well (except some minor rotation problems) ;-)
Nevertheless I'm gonna search for replacing scripts.
Thanks!
You might just try grouping your objects and using the stock "Align & Distribute" tool in your 3ds Max "Tools" menu...
There are several scripts here that do something similar as well - each with their own features... Try searching for "object replacer" and filtering to just 3ds Max Scripts"...
