hello !
I want to know how to remove or update a rollout for exemple if I have a rollout2 and I want to replace it by the rollout 3 ou 4
Here this my code :
flt= newrolloutfloater "test" 200 200
addrollout rollout1 flt
addrollout rollout2 flt
rollout rollout1 "rollout1 "
button button1 "3"
on button1 pressed do (
removerollout rollout2 flt
addrollout rollout3 flt
button button2 "4"
on button2 pressed do (
addrollout rollout4 flt
rollout rollout2 "rollout2 "
label lab1 "this rollout2"
rollout rollout3 "rollout3 "
label lab1 "this rollout3"
rollout rollout4 "rollout4 "
label lab1 "this rollout4"
I don't understand why removerollout is not working !
thank you for your help
thank you so much
Declare your rollouts before rollout1
Hi, for some reason your variables rollout2,3 and 4 don't seem to be correctly declared on the first try. (The script works perfectly when you use it a second time).
If you define your rollouts before rollout1, it works.
