here's the script from orbaz's site.
on ChannelsUsed pCont do
pCont.usePosition = true
on Init pCont do
global obj=$Shape11 --object with selected verts
on Proceed pCont do
t1 = pCont.getTimeStart() as float
if (t1<0 and classOf obj==Editable_Poly or classOf obj==Editable_Mesh) then (
for i in obj.selectedVerts do
pCont.AddParticle()
pCont.particleIndex = pCont.NumParticles() -- last particle that was added
pCont.particlePosition = i.pos
on Release pCont do
The problem is that the particle placement creates repetitive patterns when scattering few group objects in one shape instance node.
How can i randomize particles (change their position seed) after setting their birth in birth script?
Add this after pCont.particlePosition=i.pos
CurPos=pCont.particlePosition
CurPos+=pCont.randSpherePoint()*50 ---this will give 50 random units, xyz
pCont.particlePosition=Curpos
It should work, if not get back to me
