how to make a polygon from vertices selection >3?
By Nikolay Litvinov · 2013-07-31
I have such code
arrVert = (vert_sel=(polyOp.getVertSelection $.baseobject) as array) -- array of vertices
polyOp.createPolygon $ arrVert
And created face only from 3 vertices, and I would like to make a polygon from vertices selection >3.
Comments (8)
Nikolay Litvinov
I found a script (on this site) that does it
fn MakePoly = (
	constVerts = (polyop.getVertSelection $) as array
	sortedVerts = #()
	append sortedVerts constVerts[1]
	stillGood = true
	Tcount = 0
	while stillGood do
		thisVert = sortedVerts[sortedVerts.count]
		try (lastVert = sortedVerts[sortedVerts.count - 1])
		catch (lastVert = -1)
		theseEdges = (polyop.getEdgesUsingVert $ thisvert) as array
		theseEdgesVerts = for i in theseEdges collect ((polyop.getVertsUsingEdge $ i)as array)
		theRightEdge = #()
		for i in theseEdgesVerts do (if (finditem constVerts i[1] != 0 and i[1] != lastVert) and (finditem constVerts i[2] != 0 and i[2] != lastVert) then theRightEdge = i)
		if theRightEdge == #() then exit
		if theRightEdge != #() then ( if theRightEdge[1] != thisVert then (theRightVert = theRightEdge[1]) else (theRightVert = theRightEdge[2]) )
		if theRightVert == undefined then exit
		if theRightVert == sortedVerts[1] then stillGood = false else append sortedVerts theRightVert
		Tcount += 1
		if Tcount > 10 then stillGood = false
	Tcount = 0
	if sortedVerts.count != constVerts then
		sortedVerts = for i in sortedVerts.count to 1 by -1 collect sortedVerts[i]
		while stillGood do
			theRightEdge = #()
			Tcount += 1
	Tcount = 0
	while sortedVerts.count != constVerts.count do
		stillMissing = #()
		stillMissing = (constVerts as bitarray - sortedVerts as bitarray) as array
		print"Then"
		print stillMissing
		shortestDistance = length ((polyop.getVert $ sortedVerts[sortedVerts.count])-(polyop.getVert $ stillMissing[1]))
		closestVert = stillMissing[1]
		for i in stillMissing do if (length ((polyop.getVert $ sortedVerts[sortedVerts.count]) - (polyop.getVert $ i))) < shortestDistance then closestVert = i
		append sortedVerts closestVert
		while stillGood do
			theRightEdge = #()
			Tcount += 1
		Tcount+=1
		if Tcount > 30 then exit
	print "END"
	print sortedVerts
	if (polyop.createpolygon $ sortedVerts) == undefined then
	polyop.createpolygon $ (for i in sortedVerts.count to 1 by -1 collect sortedVerts[i])
	update $
Why you don't want to use Cap Poly? This is the easies method.
polyOp.createPolygon $ #(177, 145, 146, 178)
creates polygon on oject. See the attached image.
Don't use bitarray to store the selected verts. In bitarray the verts are sorted from the lower to higher vert index.
To use polyOp.createPolygon to create face from 4 verts, you have to store the selected verts in an array, where the verts are sorted in proper order. See the image - did you see the verts indexes and how I sort the verts in the array that is passed to polyOp.createPolygon. The verts order is essential when you wants to create 4 sided polygon.
Reply to miauu
Nikolay Litvinov
Okay, I agree with you. It is better to use the cap. Thank you
Nikolay Litvinov
I know about cap
But
polyOp.createPolygon $ #{ , , , }
dont create polygon on oject (works with only isolate vertex)
Creating polygon from four verts see the attached image.
Reply to miauu
Felice DeNigris
How to create vertices
How do you create vertices without the mesh?
You have to have a mesh. Create a plane, convert it to mesh, delete all verts and you will have an empty mesh and can start adding verts where you want.
Reply to Felice DeNigris
Nikolay Litvinov
If class of object == editable_mesh or editable_poly then \
Enable sub-object vertex ➜ go to righr-panel settings ➜ Create ➜ pick to viewport for create vertices
