how to make a filter selection on Array
By draging · 2013-08-27
I have 3 objects
MyObj = #($box001,$box002,$sphere001)
In my case, I want to change the wirecolor of all the objects to be red but I don't want to change the color on MyObj array, then I want to select objects that have become red.
for o in objects do
o.wirecolor = (color 255 0 0)
for i in MyObj do
i.wirecolor = -- don't change this
-- What next ? :o
I tried this but, it doesn't work.
Any suggestions?
Thank you
Comments (8)
	myObjArr = #($box001,$box002,$sphere001)	---	selection as array
	for o in objects where (findItem myObjArr o ) == 0 do
		o.wirecolor = red
Reply to miauu
draging
yess that's what I need :D
thanks miauu
but how to select them (objects with red color) ?
with 'select o' its not working correctly
Reply to draging
You have to use selectMore 0, but this is slow(in scene with many many objects) compared to this:
	objWithRedWirecolorArr = #()
		o.wirecolor = red
		append objWithRedWirecolorArr o
	select objWithRedWirecolorArr
Reply to miauu
Kostadin is right. "SelectMore" fn is slow. Anyway this is similar solution in one line
select (for o in objects where findItem MyObj o == 0 and o.wirecolor = red collect o)
hi barigazy
thank you for your attention :)
its good in one line like your scripts. but there is no function to change the color of objects to be red first, then select the objects. or vice versa: select and then change the colors...
so how to make it in one line ? :D
Reply to miauu
draging
I had read the MXS help
yup, 'selectmore' make the process slower
your script is good for faster processing
its working correctly :D
thanks again Miauu
Reply to draging
select (for o in objects where findItem MyObj o == 0 collect (o.wirecolor = red; o))
