How to get first chars of name of current stack modifier or class
By M · 2014-08-14
Hi guys !
I wrote quick script for connect in one button for vertex and edges (in Edit_poly / Editable_poly modifiers). It works perfectly unless i change name of modifier (ex. Edit_poly_randomString). How to write that script will execute its case depends of first chars of modifier (Edit_polyDOESNT_MATTER_ANY_OTHER_STRING_HERE)or get class(?) of Edit_poly / Editable_poly?
macroscript ConnectSubObjectMode
category:"All MojeSkrypty"
tooltip:"Connect uruchamiany zaleznie od subMode"
local curObj = modPanel.getCurrentObject()
	Case (classOf curObj) of
		Editable_poly:
			(	Case (subobjectLevel) of
				 1: $.EditablePoly.ConnectVertices ()
				 2: $.EditablePoly.ConnectEdges ()
				 3: $.EditablePoly.ConnectEdges ()
		Edit_Poly:
				 1: $.modifiers[#Edit_Poly].ButtonOp #ConnectVertices
				 2: $.modifiers[#Edit_Poly].ButtonOp #ConnectEdges
				 3: $.modifiers[#Edit_Poly].ButtonOp #ConnectEdges
		default:
			(	--Case (subobjectLevel) of
				 --1: $.modifiers[#Edit_Poly].ButtonOp --#ConnectVertices
				 --2: $.modifiers[#Edit_Poly].ButtonOp --#ConnectEdges
				 --3: $.modifiers[#Edit_Poly].ButtonOp --#ConnectEdges
M
Thank you very much ! :)
As you saw I not use "case of" statement because you have only two conditions that U need to check.
macroscript ConnectSubObjectMode category:"All MojeSkrypty" tooltip:"Connect uruchamiany zaleznie od subMode"
if (node = modPanel.getCurrentObject()) != undefined do
if (number = findItem #(editable_poly, edit_poly) (classOf node)) > 0 do
if subobjectLevel > 0 and subobjectLevel < 4 do
if subobjectLevel == 1 then (if number == 1 then node.ConnectVertices() else node.ButtonOp #ConnectVertices)
else (if number == 1 then node.ConnectEdges() else node.ButtonOp #ConnectEdges)
