how to fix this? loop?
By wingwingwing · 2010-06-16
I need help!
i use the following maxscript to output my variable either when transform or animate:
a=$cylinder01
b=$cylinder02
c=$cylinder03
d=$cylinder04
fs= createfile "C:\\Users\\User\\Desktop\\rotation angles1.txt"
when transform a changes handleAt:#redrawViews do (in coordsys parent format "rotation-y cylinder 01 = %\n" a.rotation.y_rotation to: fs )
fn time_cb = in coordsys parent format "rotation-y cylinder 01 = %\n" a.rotation.y_rotation to: fs
fn tcb = time_cb()
registerTimeCallback tcb
fs1= createfile "C:\\Users\\User\\Desktop\\rotation angles2.txt"
when transform b changes handleAt:#redrawViews do (in coordsys parent format "rotation-z cylinder 02 = %\n" b.rotation.z_rotation to: fs1 )
fn time_cb = in coordsys parent format "rotation-z cylinder 02 = %\n" b.rotation.z_rotation to: fs1
fn tcb = time_cb()
fs2= createfile "C:\\Users\\User\\Desktop\\rotation angles3.txt"
when transform c changes handleAt:#redrawViews do (in coordsys parent format "rotation-z cylinder 03 = %\n" c.rotation.z_rotation to: fs2 )
fn time_cb = in coordsys parent format "rotation-z cylinder 03 = %\n" c.rotation.z_rotation to: fs2
fn tcb = time_cb()
fs3= createfile "C:\\Users\\User\\Desktop\\rotation angles4.txt"
when transform d changes handleAt:#redrawViews do (in coordsys world format "rotation-z cylinder 04 = %\n" d.rotation.z_rotation to: fs3 )
fn time_cb = in coordsys parent format "rotation-z cylinder 04 = %\n" d.rotation.z_rotation to: fs3
fn tcb = time_cb()
i'm sure the script worked when it is only 1 cylinder,
But now the problem is that when i use the script above, i can only get the last files outputed, the other 3 earlier's text files is blank!
What should i do? is it i should make a loop or something else?
Can someone give example on how to fix this?
