Hi there!
I got an editable poly here and some polygons selected. Now I want to extrude each polygon by some random amount. The problem is I don't konw how to have a loop iterating over each polygon. I also don't know how to get each polygon into an array in order to iterate over each variable of the array.
All that I am currently capable of is to extrude ALL polygons by a random amount which is not what i want.
Is there any existing script for that, or how can i solve my problem?
Comments (8)
Thanks a LOT!
Works awesome THANK YOU!!
Thank you very much
How can I set the randomize extrusion step? Such as extrusion from 0 to 500 in increments of 50?
Great! but i'm too dumb
I'm sorry, but I'm stupid to max script. Tell me, please, where in the script, inserts this new part of script?
Ok :)
Here is my try, but keep in mind that I edit the script but without testing ;)
I had to put the "createDialog faceExtr" in the beginning of the script to make it work.
Nice script. Thanks.
Thank you VERY much, exactly what i needed!
Works perfectly! =)
had similar needs some time ago. here a quick (and dirty) solution. works with collapsed editable poly object only :( ...
