Howdy everyone , im kind of trying to writte maxscript but I stuck in here , please help me, here is the sample script:
rollout dynamite "Untitled"
editText edt4 "" pos:[1,3] width:155 height:24 enabled:false
createDialog dynamite 162 35
the problem is how to enable/disabled editText in dialog when I select/deselect or object count more than 1 and less than 1 the object.
Thank!
oh cool!....you can do this
function enable_event = (
callbacks.addScript #selectionSetChanged "check_selection()" id:#m3dLearnEvent
function disable_event = (
function check_selection = (
this_sel_count = (selection as array).count
dynamite.lbl_num_picked.text = "num picked: " + (this_sel_count as string)
if this_sel_count == 1 then (
dynamite.edt4.enabled = true
dynamite.edt4.text = "enabled"
dynamite.edt4.enabled = false
dynamite.edt4.text = "disabled"
rollout dynamite "Untitled" width:231 height:65
edittext edt4 "" pos:[1,3] width:155 height:24 enabled:false
label lbl_num_picked "Num Picked: 0" pos:[8,35] width:118 height:25
on dynamite close do (
disable_event()
on dynamite open do
check_selection()
enable_event()
OK I got it! THX!
Start by looking at the General Event Callback Mechanism entry in the Maxscript reference. There's enough info and examples there.
To Mertens3d:
Thank mertens3d for the answer but this is not what I meant, what I want is whenever you had object in selection, which the quantities equal one, it will enable the edit text box and disable it when the the selection count more than one or less than one,may be just like what marco said about mouse callback function, just like rappa tool maybe, when object in selection is polyOps the button comes to light and if not polyops some button is turn off ...
To marco: could you explain it more !? new in maxscript here......hehehe thank! or give me some lead or example maybe,it'll help me much...one again thank!
I think the best way to go about this would be to create a callback that fires whenever the selection is changed, and have the callback update the editText accordingly.
something like this maybe?
rollout dynamite "Untitled" width:231 height:97
label lbl_num_picked "Num Picked: 0" pos:[164,51] width:62 height:40
button btn4 "Check Selection" pos:[21,44] width:83 height:33
on dynamite open do check_selection()
on btn4 pressed do
check_selection()
there's a mousetool too which seems to give more event driven/reactor type feedback. Maybe that would work better but I don't know how to use it yet.
