How to delete some thing from multi 3dsmax files?
By gazarika · 2015-03-30
Is there a way to check and delete all cameras and lights in about 100 3ds max files and then take action about this?
mmb
want to delete Layer itself along with its content
hello
i want to delete some layers along with its content which contain geometry, light, cameras.
with this script, i can only delete camera and light is there any way to update this.
thanks for the Help!
Try this:
	global rol_miauuBatchLoadXRefScenes
    try(destroyDialog rol_miauuBatchLoadXRefScenes)catch()
    rollout rol_miauuBatchLoadXRefScenes "miauu"
		local ConvertClass = dotnetclass "system.convert"
		local ImageClass = dotnetclass "system.drawing.image"
		local logoIcon = "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"
		local curMaxVersion = ((maxVersion())[1] / 1000)
		local openFileRoll = dotNetObject "System.Windows.Forms.OpenFileDialog"
        local disableForeColor = (dotNetClass "System.Drawing.Color").white
        local maxFiles = #()
        dotNetControl lv_Batch "system.windows.forms.listView" height:200 width:273 pos:[10,10]
		button btn_getDir "Get Directory" width:108 pos:[290,10] tooltip:"Select all .max files in the given folder and/or its sub-folders"
        button btn_getFile "Get file(s)" width:108 pos:[290,35] tooltip:"Select one or multiple files in given folder"
        button btn_Clear "Cear" width:108 pos:[290,60]
		checkbox chkBox_showFullPath "Show Full Path" pos:[10,215]
		label lbl_select "Select:" pos:[120,215]
		button btn_all "All" pos:[157,214] width:40 height:18
		button btn_none "None" pos:[200,214] width:40 height:18
        button btn_invert "Invert"	 pos:[243,214]	width:40 height:18
		button btn_loadXRefScenes "Load xRef Scenes" width:275 height:30 pos:[10,235]
		hyperLink http_miauu "miauu's MaxScripts" address:"http://miauumaxscript.blogspot.com/" pos:[300,270] color:(color 7 231 251)
		progressBar pb_xRefprogress value:0 color:green width:275 pos:[10,270]
		--	Credist to Peter Addington - http://lonerobot.net/?p=314
		function String2Bmp string =
			local clipboardClass = dotNetClass "System.Windows.Forms.Clipboard"
			local imageclass = dotNetclass "System.Drawing.image"
			local bytearr = convertclass.FromBase64String string
			local memstream = dotnetobject "System.IO.MemoryStream" bytearr
			local DecodedImg = ImageClass.fromstream memstream
			memstream.close()
			DecodedImg
		--	credits to Denis Trofimiv - http://forums.cgsociety.org/showpost.php?p=7708817&postcount=21
		function LoadMyLogoAsTitlebarIcon =
			d = (windows.getChildHWND 0 rol_miauuBatchLoadXRefScenes.title)[1]
			WM_SETICON = 0x0080
			ICON_SMALL = 0
			bm = dotnetobject "System.Drawing.Bitmap" (String2Bmp logoIcon)
			ptr = bm.GetHicon()
			icon = (dotnetclass "System.Drawing.Icon").FromHandle (dotnetobject "IntPtr" ptr)
			windows.SendMessage d WM_SETICON ICON_SMALL icon.handle
        function AddColumns theLv columnsAr=
            if chkBox_showFullPath.state == false then
                w=(theLv.width)-6
                w=(theLv.width)+400
            for x in columnsAr do
                theLv.columns.add x w
        function PopulateListView theLv=
            rows=#()
            for x=1 to maxFiles.count do
                    mapName = (getFilenameFile maxFiles[x])
                    mapName = maxFiles[x]
                li = dotNetObject "System.Windows.Forms.ListViewItem" mapName
                append rows li
            theLv.items.addRange rows
        function InitListView theLv=
            theLv.clear()
			theLv.headerStyle = theLv.headerStyle.none
            theLv.view = (dotNetClass "system.windows.forms.view").details
            theLv.FullRowSelect = true
            theLv.MultiSelect = true
            theLv.checkBoxes = true
            theLv.backcolor = (dotNetClass "System.Drawing.Color").DimGray
            theLv.forecolor = (dotNetClass "System.Drawing.Color").lightGray
        function BatchListViewReIinit =
            InitListView lv_Batch
            AddColumns lv_Batch #("")
            PopulateListView lv_Batch
        function TurnBatchLVchkBoxOn =
            for i = 0 to lv_Batch.Items.count-1 do
                lv_Batch.Items.Item[i].checked = true
            lv_Batch.forecolor = disableForeColor
        function OpenFolders folderToOpen =
            local checkFolderName = substring folderToOpen 1 (folderToOpen.count-1)
            if (symbolicPaths.isPathName checkFolderName) then
                folderToOpen = symbolicPaths.getPathValue checkFolderName
            shellLaunch "explorer.exe" folderToOpen
        function GetFilesRecursive root pattern =
            dir_array = GetDirectories (root+"\*")
            for d in dir_array do
                join dir_array (GetDirectories (d+"*"))
            my_files = #()
            for f in dir_array do
                join my_files (getFiles (f + pattern))
            my_files
        on btn_getDir pressed do
            dir = getSavePath caption:"Select the directory" initialDir:"$scenes"
            if dir != undefined do
                maxFiles = #()
                --    get all max files
                maxFiles = getFiles (dir+"\*.max")
                --    check for subfolders
                subFiles = GetFilesRecursive dir "*.max"
                if subFiles.count != 0 then
                    msg = "The selected folder have subfolders!\n"
                    msg += "Do you want to include the files from the subfolders too?"
                    if queryBox  msg title:"Sub-folders found" do
                        join maxFiles subFiles
				makeUniqueArray maxFiles
                TurnBatchLVchkBoxOn()
        on btn_getFile pressed do
			result = openFileRoll.showDialog()
			result.ToString()
			if (result.Equals result.OK) do
				filePath = (openFileRoll.fileNames)
				join maxFiles filePath
                BatchListViewReIinit()
		on btn_all pressed do
			for i = 0 to lv_Batch.Items.count-1 do lv_Batch.Items.Item[i].checked = true
		on btn_none pressed do
			for i = 0 to lv_Batch.Items.count-1 do lv_Batch.Items.Item[i].checked = false
		on btn_invert pressed do
			for i = 0 to lv_Batch.Items.count-1 do lv_Batch.Items.Item[i].checked = not lv_Batch.Items.Item[i].checked
        on btn_Clear pressed do
            maxFiles = #()
        on lv_Batch MouseDown arg do
            --    delete selected max file from the listview
            if arg.button==arg.button.middle then
                if (hitNode = lv_Batch.GetItemAt arg.x arg.y) != undefined do
                    deleteItem maxFiles (hitNode.index+1)
            --    open folder of selected max file
            if arg.button==arg.button.right then
                    f = (hitNode.index+1)
                    folderToOpen = (getFilenamePath maxFiles[f])
        on chkBox_showFullPath changed state do
			cbState = for i = 0 to lv_Batch.Items.count-1 collect lv_Batch.Items.Item[i].checked
            for i = 0 to lv_Batch.Items.count-1 do lv_Batch.Items.Item[i].checked = cbState[i + 1]
		on btn_loadXRefScenes pressed do
			local xRefCnt = (lv_Batch.Items.count - 1)
			setWaitCursor()
			for i = 0 to xRefCnt where (lv_Batch.Items.Item[i].checked == true) do with redraw off
				resetMaxFile #noprompt
				loadMaxFile  maxFiles[i + 1] useFileUnits:true quiet:true
				delete cameras
				delete lights
				saveMaxFile maxFiles[i + 1] useFileUnits:true quiet:true
				pb_xRefprogress.value = 100.0 * i / xRefCnt
				if curMaxVersion > 12 do
					windows.processPostedMessages()
			setArrowCursor()
        on rol_miauuBatchLoadXRefScenes open do
			try(LoadMyLogoAsTitlebarIcon())catch()
			openFileRoll.title = "Select Files"
			openFileRoll.Multiselect = true
			openFileRoll.Filter = "MAX (*.max)|*.max"
			openFileRoll.FilterIndex = 1
			openFileRoll.RestoreDirectory = true
            AddColumns lv_Batch #("Files")
    createdialog rol_miauuBatchLoadXRefScenes width:405
I don't have time to rearange the UI. It will load all files and will delete all lights and cameras, then will save the loaded file with the same name in the same directory(the file will be overwritten).
pixamoon
Yes of course. but make sure you backup them before.
Just copy all files to one folder and change path to it -> maxfiles_Folder
This script will batch delate all camers and ligths in those files and resave them with new suffix "no_cams-lights"
maxfiles_Folder = "D:\\3d\\abc\\"
maxfiles = getFiles (maxfiles_Folder + "*.max")
for f in maxfiles do
	loadMaxFile f quiet:true #noprompt
	for o in objects where superclassof o == camera or superclassof o == light do delete o
	saveMaxFile (getfilenamepath f + getfilenamefile f + "_no-cams-lights.max")
or if you want to save them to new folder:
newFolder = "D:\\3d\\newFolder\\"
makeDir newFolder
	saveMaxFile (newfolder + getfilenamefile f + "_no-cams-lights.max")
But be careful changing / using it!
Best,
Pixamoon
Yes.
You have to batch load all 100 files, delete cameras and lights in each file, then save the file.
If you are sure that all cameras and lights have names that contains "Camera" and "Light" in it you can check the name of the objects, before loding the files, to avoid loading max file where there is no cameras or lights. Nut if the name of the cameras and lights do not have "Camera"/"Light" then you have to load all max files one by one.
