How to create a record button?
By artrender · 2013-05-18
How to create a dontnet button to display one image when pressed once, and another - when pressed second time(for example red and grey)
		--btn = dotnetobject "Button"
                dotnetcontrol btn "System.Windows.Forms.Button" pos:[667,101] width:15 height:15 border:false
		--btn.FlatStyle = btn.FlatStyle.Flat
                btn.flatstyle = dotnetobject "System.Windows.Forms.FlatStyle" Flat
                btn.Location = dotNetObject "System.Drawing.Point" 1 prevh
               i=1
             if i==1 then
                btn.image = (StringToImage record_red)
                i=0
                btn.image = (StringToImage record_grey)
just to use that if, or there is a more correct way?
Comments (13)
Yuan John
A growing number of musicians are making their music available for licensing on royalty free music websites like MusicRevolution.com.
artrender
aah
ok! Thx Barigazy! You answered to my questions! I guess you'll have a headache because of me!
Reply to artrender
No I just try to replicate free iToo Clone modifier with mxs modifier but I go to the dead end. It's not posible, only C++ can be solution. You already have same problem in another post:)
Reply to artrender
Yup. But you can't paint in dark gray separator. Not works.
Take look of properties of context menu. I used Proffesional mode and remove left part (where you add F1)
artrender
Answer!
About record button! It works great, THX, just didn't have time to convert it to work as btn.image, because I have image to display instead of text! By the way, does btn "CheckBox" support image?
Now about context menu! It shows just a shadow when pressing rightclick on record button-I mean about second script. See the attached image!
I appreciate very much your help, barigazy!!!! You're brave!
Reply to artrender
.net checkbox support images.
ContextMenu works fine I tested in max2012x64 and 2014x64
Reply to Branko Živković
Disable transparency ei. put "--" (as comment) or delete this line
--maybe this cause problem
dnCM.Opacity = 0.85d0
artrender
oh, thx Barigazy
I will try your code and I will let you know later! Thx again! Srry that I give so many questions!
artrender
on no
in my case it will be always red :)
Reply to artrender
Is this simple enought
rollout bgaRoll "• • •"
fn defColor r g b = (dotNetClass "System.Drawing.Color").FromArgb r g b
fn defFont fName fSize = (dotNetObject "System.Drawing.Font" fName fSize ((dotNetClass "System.Drawing.FontStyle").bold))
local C1 = defColor 100 100 100, C2 = defColor 0 0 0, C3 = defColor 150 20 20, C4 = defColor 220 220 220, Fnt = defFont "Verdana" 30
dotnetcontrol btn "CheckBox" pos:[10,10] width:180 height:80
on bgaRoll open do
btn.BackColor = C1 ; btn.ForeColor = C2 ; btn.font = Fnt
btn.Text = "• REC" ; btn.Appearance = btn.Appearance.Button
btn.TextAlign = btn.TextAlign.MiddleCenter ; btn.FlatStyle = btn.FlatStyle.Flat
btn.FlatAppearance.BorderSize = 10 ; btn.Cursor = (dotNetClass "Cursors").Hand
btn.FlatAppearance.CheckedBackColor = btn.FlatAppearance.MouseDownBackColor = C3
--btn.FlatAppearance.MouseOverBackColor = C1
--dnCBtn.FlatAppearance.BorderColor = C2
on btn MouseUp arg do
if btn.checked then btn.forecolor = C4 else btn.forecolor = C2
createDialog bgaRoll 200 100 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
And finaly I add example with ContextMenuStrip that you asked in previous post
Here we go. Just press RMB over button
fn defSize x y = (dotNetObject "System.Drawing.Size" x y)
fn defPoint x y = (dotNetObject "System.Drawing.Point" x y)
local Fnt1 = defFont "Verdana" 30, Fnt2 = defFont "Verdana" 6.5
fn defCnxMenu dnCM items:#("Record1", "Record2", "Record3", "Record4") =
fn defTSMI itmStr =
local itm = dotNetObject "ToolStripMenuItem" itmStr ; itm.BackColor = C1
itm.AutoSize = off ; itm.Size = defSize 80 20 ; itm.Font = Fnt2 ; itm
dnCM.RenderMode = dnCM.RenderMode.Professional
dnCM.ShowCheckMargin = dnCM.ShowImageMargin = dnCM.AutoSize = off
dnCM.Size = defSize 81 84 ; dnCM.Opacity = 0.85d0
dnCM.Items.AddRange (for i in items collect (defTSMI i))
dotNet.addEventHandler dnCM "ItemClicked" \
fn cnxMenuClick s e =
case e.ClickedItem.Text of
("Record1"): print "Start Record1"
("Record2"): print "Start Record2"
("Record3"): print "Start Record3"
("Record4"): print "Start Record4"
on bgaRoll open do
local dnCM = dotNetObject "ContextMenuStrip" ; defCnxMenu dnCM
btn.BackColor = C1 ; btn.ForeColor = C2 ; btn.font = Fnt1
btn.ContextMenuStrip = dnCM
if arg.Button == arg.Button.Right do (btn.ContextMenuStrip.Show btn (defPoint arg.x arg.y))
edit
If you need to change items count or font size in CMS you need also adjust height and width
--in this lines
