Hey Guys,
I have two hand controls in a rig that control the curl and splay of the fingers. The rotations of the finger bones are wired to some custom attributes of the hand controls. I animated one hand and now i want to copy those keys over to the other hand. I found this script to copy custom attribute keys from one Attribute Holder modifier to another:
http://www.scriptspot.com/3ds-max/scripts/custom-attrubute-animation-cop…
But my CA's are stored in a PEN_Attribute_Holder 2, which is a scripted modifier by Paul Neale, with some nice features. So it doesnt work for me. Does anyone know how I could modify the script to make it work with the PEN_Attr_Holder? I havent found out how to access the modifier.
Greetings
That is exactly what I tried to do, but I do not have any idea how to check its name ^^....
Well, open the source file of the modifier plugin (if not encrypted), else you can also see its name in the Max Modifier panel, or variant 3 - via MaxScript: create a Dummy and add the mod, then (it still selected)...
I hope this help.
Thanks, I can access the modifier now. I renamed the modifier and did not think of it in the first time. Anyways, the script still does not work yet. It tells me it does not find any Modifier/Custom Attributes on the Object. But maybe I will find out why, thanks again.
Im not use PEN scripts but looks simple to fix this, just open the script that copy CA's keys and find and replace (Ctrl+H) all the
name with the scripted modifier name, e.g.
(or check its name).
