Hello everybody!
I wanna add a custom attributes to a spline to control the animation. I added a listbox and a pickbutton to it, and gonna achieve this: picked an object then the object's name display in the listbox item.
Here's my script:
testCA = attributes listBoxTest
parameters main rollout:params
rollout params "Test"
fn shapesOnly obj = isKindOf obj shape
listBox objLb ""
pickbutton objPb "Pick an Object" filter:shapesOnly
on objPb picked obj do
objLb.items = #(obj.name)
custAttributes.add $.modifiers[1] testCA
But when I selected another object then select the object again, the data was gone.
So how to save the data? I know that I should set some parameters but how to do it?
Thank you.
I’ve read the MAXScript Help file again and rewrite it:
rollout paramsRoll "Parameters"
listBox objLb ""
append $Point01.modifiers[1].listBoxTest.nodes obj
append $Point01.modifiers[1].listBoxTest.nodesNames obj.name
objLb.items = $Point01.modifiers[1].listBoxTest.nodesNames as array
on paramsRoll open do
on paramsRoll close do
local lastDialogPos = getDialogPos paramsRoll
$Point01.modifiers[1].listBoxTest.dialogPos[1] = lastDialogPos.x
$Point01.modifiers[1].listBoxTest.dialogPos[2] = lastDialogPos.y
parameters main rollout:ctrlRoll
nodes type:#nodeTab tabSizeVariable:true
nodesNames type:#stringTab tabSizeVariable:true
dialogPos type:#intTab tabSize:2
rollout ctrlRoll "Control"
button floatBt "Float..."
on floatBt pressed do
createDialog paramsRoll 168 215 dialogPos[1] dialogPos[2]
addModifier $ (emptyModifier())
This time it worked very well.
