How to connect two vertices of a poly ?
By titane357 · 2015-10-08
I Wonder how to connect two vertices of a poly with maxscript ?
can't find... :-(
Comments (7)
Eva Visnjic
I use Target Weld to combine two vertices that are far apart, resulting in a single vertex that's in the same position as one of them.
Eva Visnjic on Facebook
titane357
hi,
sorry, but I need to connect one vertex, with several vertices, in one go.
I mean, select somes vertices, and connect the last one to the other.
I would be (it is) very handy in many cases.
titane357
Thanks for answer miauu, but it is bitarrays... (I will never understand..)
how can I connect the last selected vertex to the other ?
Reply to titane357
Select both vertices, no matter if they are stored in bitarray or in array. Then execute the command and they will be connected.
The command is #ConnectVertices
So, select 2 verts then execute this(for editable poly objects)
$.buttonOp #ConnectVertices
