Hello,
I have problem to use tape tool because it is too awfull.
Could it be possible to have just point helpers with center marker (not the cube and the arrow...) ???
how to change tape object aspect ?
By titane357 · 2010-08-25
Comments (8)
Hi again, I was playing a little with extending Point helper and end with some working version that you may test ;)
hello,
I tried your script on maxdesign2011, and I got :
"--Unable to convert: undefined to type:Float" :-(
Oh, yes, I forget some note... I need to write a mouse create tool for this plugin to can use the button from Create panel. Now you can create ane TapeX object using the constructor i.e. "TapeX()" (the same as creating box for exmple - "Box()"). So type in the Listener "TapeX()" just to test it, and if you like it, I'll try to add mouse create tool ;)
hello anubis,
In fact I'd like to change max's tape object (in a init file ?), or do another.
Your script let the pyramidal object...
I'd be great to have more elegant (graphical) objects in max.
Thanks for help. :-)
RE: "Your script let the pyramidal object..."
The alternative you're looking for is a new helper plugin, but if only this objects disturb then just hide it. Also to auto-hide the pyramidal object you can include isHidden property at creation time in the example script, i.e.:
[code]tape name:"Tape2" pos:[0,0,50] isHidden:true \
parent:(point name:"Tape_parent2" pos:[0,0,50]) \
target:(point name:"Tape_target2"){/code]
argh, now just "Tape_target2" is visible....
drat! :( you're right
Hi Titane, is this?... tape
