How to change 3dsmax default values?
By gazarika · 2015-04-07
for example
#how to change the default real size map from 1.0cm to 100.0 cm?
#how to change the default sweep shape in the sweep modifier to rectangle and its dimensions values?
#how to change the default spline vertexes value to corner instead of bezier?
pixamoon
I don't know if max stores those settings somewhere but for sweep defaults you can use my startup script:
This one is to use box in sweep profile. Just copy it to program Files\...Max\scripts\Startup\
I'm working on the script to save/load all kind of defaults... I'll post first version soon.
Best,
Pixamoon
