How to call MaxScript in windows command line or program languages like Java?
By gloomy · 2008-07-22
As subject, I want to integrate maxscript files to an automatical pipeline so that I don't need to open it one by one and run. Any ideas? Thanks in advance.
gloomy
Thank you very much for your answer.
Jenne van der Meer
Just a mxs suggestion:
getFiles <wild_card_filename_string>
files = getFiles @"c:\foo\*.ms"
for file in files do fileIn file
or include.
For more details see "External File Methods" in the mxs help file. And if that is to limited id check dotNet which can just be coded in max.
Calling maxscripts from commandline seems a bit odd since it requires 3dmax its not a standalone program, but a script..
