IList propertyNames = TheJObject.Properties().Select(p => p.Name).ToList();
this is the code in .net i'm trying to use JSON library. Everything is fine but i can not handle "p => p.Name" part, what is it, how does it work and how can i change it to maxscript? I need it to be able to create a loop.
Thanks in advance.
Comments (10)
Sekopasa, any progress?
I am currently looking at JSON.NET in max script as well
And I'm pretty much at the same point you were in this post
Hey Mambo4,
i not try jet JSON.NET. Tell me what is the adventage ei. purpose of json.net in combination with mxs.
Cheers!
I'm writing MAX export tools for a game engine that uses JSON to load its assets.
functionally JSON does the same thing as XML, which I guess most Max tools utilize.
but it's less verbose and slightly smaller in file size.
my background is manipulating JSON with MAYA/PYTHON, so I like it better.
Jsont.net is simply the first library I found for using json in dot net. It looks powerful, but getting it to cooperate with mxs is a challenge.
Cool. Thanks for the explanation.
Ok the project is recreating Daz Studio materials in 3dsmax/Vray at least getting the texturemaps connected to materials.
Daz Studio exports a DSF file which is a JSON file defining the materials. I achieved to get the file into 3dsmax i can reach the values by keynames.
But i realised that i would need loops in some cases. JObject has a count value but you can not reach the values like an array. I was looking for how to create a loop, i thought if i had the property names in an array i would create my own loop.
So i found this thread.
http://json.codeplex.com/discussions/231381
this is what i get with showproperties
.Count : <System.Int32>, read-only
.EqualityComparer : <Newtonsoft.Json.Linq.JTokenEqualityComparer>, read-only, static
.First : <Newtonsoft.Json.Linq.JToken>, read-only
.HasValues : <System.Boolean>, read-only
.Item[<System.String>propertyName] : <Newtonsoft.Json.Linq.JToken>
.Item[<System.Object>key] : <Newtonsoft.Json.Linq.JToken>
.Last : <Newtonsoft.Json.Linq.JToken>, read-only
.Next : <Newtonsoft.Json.Linq.JToken>
.Parent : <Newtonsoft.Json.Linq.JContainer>
.Previous : <Newtonsoft.Json.Linq.JToken>
.Root : <Newtonsoft.Json.Linq.JToken>, read-only
.Type : <Newtonsoft.Json.Linq.JTokenType>, read-only
(by the way getPropNames is not working)
I can send the code but there is nothing fancy in it. Maybe i can upload a dsf file somewhere if you like to see. You can open it with text editor.
Yep, you can attach *.dsf below. This is interesting.
I know a little dotnet+mxs integration but JSON is not my specialty.
I have a few questions:
#1] Tell me, you use showproperties for what?
#2] If I understand correctly what you need is to convert DAZ material to VRayMtl.Right?
#3] I try something like this
ss = stringstream ""
showproperties $ to:ss
str = ss as string
arr = filterstring str " : "
for i = 1 to arr.count where mod i 2 != 0 collect arr[i]
--#(".smooth", ".radius", ".segs", ".mapcoords", ".slice", ".hemisphere", ".sliceFrom", ".sliceTo", ".chop", ".recenter", ".realWorldMapSize")
#1 Just to see which properties i can call
#2 Exactly.
#3 This is not what i actualy need but i didnt know that i could use "to" to store the printed values.
t1 - t3 is the most basic form of a material but for example in t5 its different. There is a "extra" slot and all the material is stored in that slot.
But i will give you a example, after i get the dsf file into a Jobject i can reach the values like below. What i need is to get the keys(strings) needed to call the values.
This is not easy task. If other members can't solve this i suggest you to post this topic on CGTalk forum
http://forums.cgsociety.org/forumdisplay.php?f=6
Ok, thank you for trying. At least i learned something from you.
you can simply use
or explain what you want to collect,
