how to access vray render settings?
By V-MOTION · 2011-10-05
i know showproperties renderer.current
will show me vray properties, but how can i access them?
i have done this with vray camera that wokred, through getVrayPhysicalCamera()
but how to accesss vray render settings like noise threshold, gamma, dmc subdivisions
i can see the commands but i dont know how to access because of the renderer.current command
Raymond Homme Ingebretsen
Here is a list i found in
Here is a list in case you don't get anything in the listener:
showproperties vr
  .imageSampler_type : integer
  .filter_on : boolean
  .filter_kernel : maxObject
  .filter_size : float
  .filter_paramA : float
  .filter_paramB : float
  .filter_paramC : float
  .fixedRate_subdivs : integer
  .fixedRate_rand : boolean
  .twoLevel_baseSubdivs : integer
  .twoLevel_fineSubdivs : integer
  .twoLevel_showSamples : boolean
  .twoLevel_useDMCSamplerThresh (twoLevel_useMCSamplerThresh) : boolean
  .twoLevel_threshold : float
  .adaptiveSubdivision_minRate : integer
  .adaptiveSubdivision_maxRate : integer
  .adaptiveSubdivision_threshold : float
  .adaptiveSubdivision_rand : boolean
  .adaptiveSubdivision_showSamples : boolean
  .imageSampler_outline : boolean
  .imageSampler_mtlID : boolean
  .imageSampler_normal : boolean
  .imageSamper_normal_threshold : float
  .imageSampler_zvalue : boolean
  .imageSampler_zvalue_threshold : float
  .gi_on : boolean
  .gi_refractCaustics : boolean
  .gi_reflectCaustics : boolean
  .gi_primary_type : integer
  .gi_primary_multiplier : float
  .gi_secondary_type : integer
  .gi_secondary_multiplier : float
  .gi_saturation : float
  .gi_contrast : float
  .gi_contrast_base : float
  .gi_saveMapsPerFrame : boolean
  .gi_ao_on : boolean
  .gi_ao_amount : float
  .gi_ao_radius : worldUnits
  .gi_ao_subdivs : integer
  .gi_rayDistanceOn : boolean
  .gi_rayDistance : float
  .gi_irradmap_minRate : integer
  .gi_irradmap_maxRate : integer
  .gi_irradmap_subdivs : integer
  .gi_irradmap_interpSamples : integer
  .gi_irradmap_colorThreshold : float
  .gi_irradmap_normalThreshold : float
  .gi_irradmap_distThreshold : float
  .gi_irradmap_showSamples : boolean
  .gi_irradmap_showCalcPhase : boolean
  .gi_irradmap_showDirectLight : boolean
  .gi_irradmap_preset : integer
  .adv_irradmap_interpolationType : integer
  .adv_irradmap_mode : integer
  .adv_irradmap_dontDelete : boolean
  .adv_irradmap_loadFileName : filename
  .adv_irradmap_saveFileName : filename
  .adv_irradmap_calcInterpSamples : integer
  .adv_irradmap_useCurrentPassSamples : boolean
  .adv_irradmap_autoSave : boolean
  .adv_irradmap_autoSaveFileName : filename
  .adv_irradmap_switchToSavedMap : boolean
  .adv_irradmap_randomize : boolean
  .adv_irradmap_lookupType : integer
  .adv_irradmap_checkSampleVisibility : boolean
  .adv_irradmap_limitSearchRange : boolean
  .gi_irradmap_multipleViews : boolean
  .gi_irradmap_blurGI : float
  .gi_irradmap_detail_on (irradmap_detail_on) : boolean
  .gi_irradmap_detail_radius (irradmap_detail_radius) : float
  .gi_irradmap_detail_subdivsMult (irradmap_detail_subdivsMult) : float
  .gi_irradmap_detail_scale (irradmap_detail_scale) : integer
  .gi_irradmap_previewMode (irradmap_previewMode) : integer
  .gi_irradmap_interpFrames : integer
  .caustics_on : boolean
  .caustics_searchDist : worldUnits
  .caustics_maxPhotons : integer
  .caustics_multiplier : float
  .caustics_mode : integer
  .caustics_dontDelete : boolean
  .caustics_loadFileName : filename
  .caustics_saveFileName : filename
  .casutics_autoSave : boolean
  .caustics_autoSaveFileName : filename
  .caustics_switchToSavedMap : boolean
  .caustics_maxDensity (caustics_maxDens) : worldUnits
  .caustics_showCalcPhase : boolean
  .environment_gi_on : boolean
  .environment_gi_color : RGB color
  .environment_gi_color_multiplier : float
  .environment_gi_map : texturemap
  .environment_gi_map_on : boolean
  .environment_rr_on : boolean
  .environment_rr_color : RGB color
  .environment_rr_color_multiplier : float
  .environment_rr_map : texturemap
  .environment_rr_map_on : boolean
  .environment_refract_on : boolean
  .environment_refract_color : RGB color
  .environment_refract_color_multiplier : float
  .environment_refract_map : texturemap
  .environment_refract_map_on : boolean
  .gbuffer_channelMask : integer
  .colorMapping_type : integer
  .colorMapping_darkMult : float
  .colorMapping_brightMult : float
  .colorMapping_gamma : float
  .colorMapping_affectBackground : boolean
  .colorMapping_clampOutput : boolean
  .colorMapping_clampLevel : float
  .colorMapping_subpixel : boolean
  .colorMapping_adaptationOnly : boolean
  .colorMapping_linearWorkflow : boolean
  .camera_type : integer
  .camera_overrideFOV : boolean
  .camera_fov : float
  .camera_cyl_height : float
  .camera_fish_autoDistance : boolean
  .camera_fish_distance : float
  .camera_fish_curve : float
  .dof_on : boolean
  .dof_distance : worldUnits
  .dof_getFromCamera : boolean
  .dof_shutter : worldUnits
  .dof_subdivs : integer
  .dof_bias : float
  .dof_sides_on : boolean
  .dof_sides_num : integer
  .dof_sides_rotation : angle
  .dof_anisotropy : float
  .moblur_on : boolean
  .camera_motion_blur : boolean
  .moblur_duration : float
  .moblur_intervalCenter : float
  .moblur_geomSamples : integer
  .moblur_prepassSamples : integer
  .moblur_dmc_minSamples (moblur_minSamples) : integer
  .moblur_geometryParticles : boolean
  .moblur_bias : float
  .system_distributedRender : boolean
  .system_raycaster_maxLevels : integer
  .system_raycaster_minLeafSize : worldUnits
  .system_raycaster_faceLevelCoeff : float
  .system_raycaster_memLimit : integer
  .system_instancedObjects : integer
  .system_raycaster_optLevel : integer
  .system_region_x : integer
  .system_region_y : integer
  .system_region_meaning : integer
  .system_region_sequence : integer
  .system_region_sequence_reverse : integer
  .system_previousRender : integer
  .system_region_lockSize : boolean
  .system_frameStamp_on : boolean
  .system_frameStamp_string : string
  .system_frameStamp_fullWidth : boolean
  .system_frameStamp_justify : integer
  .system_workInCameraSpace : boolean
  .system_checkForMissingFiles : boolean
  .system_optimizedAtmospherics : boolean
  .system_lowThreadPriority : boolean
  .system_vrayLog_show : boolean
  .system_vrayLog_level : integer
  .system_vrayLog_file : filename
  .system_vrayLog_ccToDebugger : boolean
  .system_numThreads : integer
  .dmc_timeDependent (mc_lockToPixels) : boolean
  .dmc_importanceSampling (mc_importanceSampling) : float
  .dmc_earlyTermination_amount (mc_earlyTermination_amount) : float
  .dmc_earlyTermination_threshold (mc_earlyTermination_threshold) : float
  .dmc_earlyTermination_minSamples (mc_earlyTermination_minSamples) : integer
  .dmc_subdivs_mult (mc_subdivs_mult) : float
  .dmc_pathSampler_type (mc_pathSampler_type) : integer
  .photonMap_bounces : integer
  .photonMap_searchDist : worldUnits
  .photonMap_autoDist : boolean
  .photonMap_maxPhotons : integer
  .photonMap_convert : boolean
  .photonMap_interpSamples : integer
  .photonMap_multiplier : float
  .photonMap_convexHullEstimate : boolean
  .photonMap_storeDirectLight : boolean
  .photonMap_retraceCorners : float
  .photonMap_retraceBounces : integer
  .photonMap_maxDensity : worldUnits
  .photonMap_mode : integer
  .photonMap_loadFileName : filename
  .photonMap_saveFileName : filename
  .photonMap_dontDelete : boolean
  .photonMap_autoSave : boolean
  .photonMap_autoSaveFileName : filename
  .photonMap_switchToSavedMap : boolean
  .photonMap_showCalcPhase : boolean
  .options_displacement : boolean
  .options_lights : boolean
  .options_hiddenLights : boolean
  .options_shadows : boolean
  .options_defaultLights : integer
  .options_reflectionRefraction : boolean
  .options_limitDepth : boolean
  .options_maxDepth : integer
  .options_maps : boolean
  .options_filterMaps : boolean
  .options_transpMaxLevels : integer
  .options_transpCutoff : float
  .options_dontRenderImage : boolean
  .options_overrideMtl_on : boolean
  .options_overrideMtl_mtl : material
  .options_showGIOnly : boolean
  .options_ray_bias : float
  .options_glossyEffects : boolean
  .options_geom_backfaceCull : boolean
  .options_mtl_filterMaps_indirect : boolean
  .options_useLegacyModels : boolean
  .options_use3dsMaxPhotometricUnits : boolean
  .output_on : boolean
  .output_aspectlock (Lock_aspect) : boolean
  .output_imageaspect (Image_aspect) : float
  .output_width : integer
  .output_height : integer
  .output_aspect : float
  .output_fileOnly : boolean
  .output_saveFile : boolean
  .output_fileName : string
  .output_saveRawFile : boolean
  .output_rawFileName : filename
  .output_useram : boolean
  .output_genpreview (output_genrpeview) : boolean
  .output_splitgbuffer : boolean
  .output_splitfilename : filename
  .output_splitbitmap : bitmap
  .output_getsetsfrommax : boolean
  .output_splitRGB : boolean
  .output_splitAlpha : boolean
  .output_renderType : integer
  .output_regxmin : integer
  .output_regxmax : integer
  .output_regymin : integer
  .output_regymax : integer
  .output_force32bit_3dsmax_vfb : boolean
  .output_rawExrUseHalf : boolean
  .displacement_overrideMax : boolean
  .displacement_edgeLength : float
  .displacement_viewDependent : boolean
  .displacement_maxSubdivs : integer
  .displacement_tightBounds : boolean
  .displacement_amount : float
  .displacement_relative : boolean
  .dmcgi_subdivs (mcgi_subdivs) : integer
  .dmcgi_depth (mcgi_depth) : integer
  .lightcache_subdivs : integer
  .lightcache_sampleSize : float
  .lightcache_filter_type : integer
  .lightcache_filter_size : float
  .lightcache_bounces : integer
  .lightcache_showCalcPhase : integer
  .lightcache_storeDirectLight : integer
  .lightcache_multipleViews : boolean
  .lightcache_scale : integer
  .lightcache_mode : integer
  .lightcache_retrace_on : boolean
  .lightcache_retrace_threshold : float
  .lightcache_loadFileName : filename
  .lightcache_saveFileName : filename
  .lightcache_interpSamples : integer
  .lightcache_prefilter_on : boolean
  .lightcache_prefilter_samples : integer
  .lightcache_dontDelete : boolean
  .lightcache_autoSave : boolean
  .lightcache_autoSaveFileName : filename
  .lightcache_switchToSavedMap : boolean
  .lightcache_useForGlossyRays : boolean
  .lightcache_numPasses : integer
  .lightcache_adaptiveTracing : boolean
  .lightcache_adaptiveTracing_dirsOnly (lightcahe_adaptiveTracing_dirsOnly) : boolean
  .lightcache_minPathsPerSample : integer
  .excludeListOverrideMtl : node array
  .includeListOverrideMtl : node array
JokerMartini
Tassel's got it!
it will all be in the listener
vr=renderers.current
showproperties vr
mjbg
i dont know if this happens on all 3d max. But if you want to see what you are doing on the MaxScript Listener, just click to create some vray object like a vray plane or camera or anything else but do not create the object
then you can mess with the properties or with the render properties and it will show on the listener
hope it helps
In The MAXScript listener:
Firs type: vr=renderers.current
Then Type: showproperties vr
You can search for VRay scripts here at the forum also and analyse the code in them if the're not encrypted ;)
Nice place to ask such questions:
http://www.chaosgroup.com/forums/vbulletin/
