How to access at the Hierarchy/IK panel
By gianpaolo · 2007-10-17
Hello all!
I'm a newbye here and a very novice scripter :) I've found a lot of interesting and useful information in this community, thanks to share!
My first post it's a question beacause I don't found solutions in any documentations that i've read...
Does anyone know how to access via maxscript to the Hierarchy/IK panel in 3dsmax to change the START and the END parmeters?
thanks in advance!
gianpaolo.
Aline3D
owww.. I understand other thing :p
I'm sorry...
I can't help you :(
Aline3D
$.controller.startJoint
$.controller.endJoint
type in Listener: "showproperties $.controller" (with a IK selected) and it's return the properties accessible of IK
.swivelAngle (Swivel_Angle) : angle
.startJoint (Start_Joint) : node
.endJoint (End_Joint) : node
.ikSolver (IK_Solver) : string
.autoEnable (AutoEnabled) : boolean
.autoSnap (Auto_Snap) : boolean
.dispGoal (Display_Goal) : boolean
.goalSize (Goal_Display_Size) : worldUnits
.dispEffector (Display_Effector) : boolean
.effectorSize (Effector_Display_Size) : worldUnits
.dispVH (Display_VH) : boolean
.vhSize (VH_Display_Size) : worldUnits
.vhLength (VH_Display_Length) : worldUnits
.dispSolver (Display_Solver) : boolean
.posThresh (Position_Threshold) : worldUnits
.rotThresh (Rotation_Threshold) : float
.iterations (Iteration_Limit) : integer
.useVHTarget (Use_Vector_Handle_Target) : boolean
.VHTarget (Vector_Handle_Target) : node
.SAParent (Swivel_Angle_Parent_Space) : radiobtnIndex
.IK_Goal : transform
.Enabled : float
Reply to Aline3D
gianpaolo
Aline, thanks for your reply but I don't have found the command to control the START and END time...
I've attached a .gif file for more clarity.
Thanks again for your time!
gianpaolo.
