Hi!
I try to access attachment controler key in one of my scripts. But It did not work when the Attachment Controler is under a Position List Controler...
Anyone know why??? I'm not a script master and I certainly forget something.
Thank You in advance!
You can try this...
Create 3 cubes: One at the center of your scene (name it PARENT) and two smaller (Name them "A" and "B") Attach "A" to the PARENT with a standard Attachment controler (at Position controler root...) and the "B" with the Attachment controler in second position (in a Position list...).
Now try those command line :
Thekey = attachCtrl.getkey $A.position.controller 1
Thekey = attachCtrl.getkey $B.position.controller[2] 1
and you will get
#ReferenceTarget key(1 @ 0f) for "A"
and
#ReferenceTarget for "B"
strange...
If you upload an example simple scene (saved with Max2009 or below) then probably me on someone else can see whats up inside.
Meanwhile read "Value > MAXWrapper > Controllers > PositionController > Attachment Controller Keys" page in the mxs-help. There is an example as well.
Thank You it have solve my
Thank You it have solve my issue!!! The only way to acces attachment controller key is by using controller name???
But I get a strange result. Something very weird about Position value.
After passing trought my script the object position in the type-in window is
x: 100000000.0 y: 100000000.0 z: 100000000.0
And $.pos give to me :
[-1.#IND,-1.#IND,-1.#IND] ( instead of normal coordinate like [-43.2913,3.52432,18.0376] )
If I recreate manually the constraint with the same face# and the same face coordinate I get [-43.2913,3.52432,18.0376] . I get no error just this strange result.
Maybe I should open a other thread...
here is...
