How do you change bitmap color based on color picker? Need some help.
By JokerMartini · 2010-04-29
How do I get the color of the created bitmap to use the color chosen in the Color Picker? It seems like it should be something simple but I am unable to figure it out. Help would be appreciated. Thanks
John
rollout color1 "color"
colorpicker theColor "Bar Color: " color:[0,0,255] modal:false
button btnMake "Make" width:140 height:24
on btnMake pressed do
bm1=bitmap 100 100 color:red
pasteBitmap bm1 bm1 (box2 0 0 25 50) [100,100]
display bm1
createDialog color1 150 60
JokerMartini
In the same script how do I go about pasting a string of text over the blue background. Just a simple line of text like "Hello how are you?"
I've been having issues getting that to work right.
John
I see your from riverside CA, I'm from Long Beach CA!
JokerMartini
Alright great. Thanks a ton!
Chris Grant
I moved your question to the scripting forum...
To answer your question - you don't need to paste anything into the bitmap you just need to use a variable to store the color from the color picker then create a bitmap directly with that color.
curcolor = theColor.color
bm1=bitmap 100 100 color:curcolor
display bm1
