on yuzspline pressed do
mergeMaxFile "$scenes\yuzkontrolspline.max"
)running this code
but calling from within the C:\Users\Yunus11\Documents\3dsMax\scenes\yuzkontrolspline.max
I wish calling from within the E:\kurulum\Autodesk\3ds max 2011 64\scenes\yuzkontrolspline.max
mergeMaxFile (getDir #scenes + "/yuzkontrolspline.max")
)this code did not work
how do?
problem
(getDir #scene + “/yuzkontrolspline.max") [color=red]<-----not equal----->[/color] E:\kurulum\Autodesk\3ds max 2011 64\scenes\yuzkontrolspline.max
(getDir #scene + “/yuzkontrolspline.max")[color=red]<-----equal----->[/color] C:\Users\Yunus11\Documents\3dsMax\scenes\yuzkontrolspline.max
so it does not work
correct script
getDir look into your current project folder
'$scene' or '(getDir #scene)' or '(pathConfig.GetDir #scene)' - all refer/search into '%Current_Project_Folder%/scenes'.
so you may swith the project folder with 'pathConfig.setCurrentProjectFolder %PRJ_ROOT_FOLDER%' or more simply - just supply full path like:
This script works
But this script did not work
What should I do?
