I have a script that checks for updates on a FTP server & updates some materials automatically.
Now I want it to run at startup of a specific max file. I know I can place it in certain folders as Startup Scripts, but then they'll run on every startup.
Any ideas
Eran?
Hi Ofer,
Thanks for the help, I already went with the callbacks.addScript route. Works fine.
Great to see someone from Israel :-)
& some great scripts on your site
Eran
If I understand you correctly, you wish to run the script every time a specific file is opened. If so, I would do it like so:
First, you will have save save some variable with the file. There are a few way to do this:
1. Use appData. e.g. setAppData globalTracks 654321 "update from ftp"
2. Use a persistent global variable. e.g. persistent global g_UpdateFromFTP = true
3. Use a custom attribute on a global track.
I would use the appData method, as persistent globals had issues in older versions of max. It should be safe to use them since max 8, though.
Next, write a small script that will be placed in the scripts/startup folder. This script should look something like:
callbacks.addScript #filePostOpen "if getAppData globalTracks 654321 == \"update from ftp\" then fileIn \"path/to/your/script.ms\"" id:#updateFromFTP
-- Or if you used the persistent global option use the following:
--callbacks.addScript #filePostOpen "if g__UpdateFromFTP == true then fileIn \"path/to/your/script.ms\""
hOpe this helps,
o
