on execute do
for object in selection do
if (classOf object.material == Standard) then
if object.material.selfIllumAmount != 100 then
object.material.showInViewport = on
object.material.selfIllumAmount = 100
Else
object.material.selfIllumAmount = 0
else if (classOf object.material == Multimaterial) then
for b = 1 to b = object.material.numsubs do
if (classOf object.material.materialList[b] == Standard) then
How do I get this script that would work with Multimaterials? Get an error. Thanks
By Nikolay Litvinov · 2013-08-06
Budi G Great thanks!!
it works
Try this one. If not works then put fn inside execute event
fn changeMtl mtl =
if isKindOf mtl Standard do
mtl.showInViewport = on
mtl.selfIllumAmount = if mtl.selfIllumAmount != 100 then 100 else 0
on execute do
if selection.count != 0 do
for obj in selection where obj.material != null do
case (classof obj.material) of
(multimaterial): for m in obj.material.materialList do changeMtl m
(standard): changeMtl obj.material
Thanx barigazy
And How to make this for button is pressed when mtl.selfIllumAmount == 100
And If mtl.selfIllumAmount != 100 then button is not pressed.
For example as well as here but i not сan make this script as well as here
are you want to toggle VertexTicks properties ei. when VertexTicks == on then macro button is checked and if VertexTicks == off then uncheck button?
I've check your script Nik,
Don't forget to write ".materialList[b]" for Multimaterial
The result of the correction :
