How do I bridge from a rollout to another
By yunusbbayram · 2011-06-02
global spn, label1
rollout test2 "test2"
  spinner spn "spinner"
	label label1 ""
rollout test1 "test1"
	button btn "ok"
	on btn pressed do
		btn.text="okey"
		test1.title="test1rollout" as string
		spn.text="spinner ok"   -------eror
		label1.text = "okey"    -----------eror
 anapen = newRolloutFloater "YÜZ KONTROL 1.5" 200 200
addrollout test1 anapen
addrollout test2 anapen    rolledup:false
How do I
I want to change spn.text, label1.text and test2.title on btn pressed do
Where did I go wrong?
br0t
There are no "spn" and "lbl"
The way you tried this with globals does not work.
You have to tell it where to find the UI items using the dotted notation:
     test2.spn.text="ok"
     test2.label1.text = "okey"
Cheers
