How create a Password for open a script?
By Michele Marcelli · 2010-11-29
How create a password to open an encrypted script?
I tried to use "Encrypted Files" but I did not understand how...
I want to implement my script "Create Encrypted Script" with the opportunity to enter a security password.
Suggestions?
Thanks Michele
Hi Michele,
here is what i did for you, try it,
and hope it is what you need,
ui
or at least will pointer you where to look ;-)
Reply to Panayot Karabakalov
Michele Marcelli
Yes, Anubis thanks. Is what I was looking for :) I hope now understand how you used to create the password script :) Again, a big thanks :) :)
Graph
you could use encryptFile to encrypt your files and either use the encryption key as passwword or convert your password string to numbers and use that for the key
but then youll need a launcher for those scripts wich decrypts them with the password and executes the content
or if thats not what you meant, on eval of the script pop up a rollout with an editText, if the correct password is entered close that rollout and execute the main part
Reply to Graph
Michele Marcelli
Hi Graph :)
In fact it is the second part of your answer I want to do.
WorkFLow:
When I create encrypted script, I want a option for insert a password:
Create file .mse without password
Create file .mse with password
Now, the "encryptFile" I do not understand how it works ... are whole days that I try :(
Anyway, thanks for the reply :)
