How can I write ONLY numbers in EditText? (no letters accepted)
By Michele Marcelli · 2011-11-11
Hi All man! :)
My question is simple, but I can not find answer... :(
How can I write ONLY numbers in EditText? In essence, I have to write only numbers and not letters...
Situation:
I write any numbers in editText and I've as result in label (like addition, division ecc).
I write any word or letter and I've as result a messagebox like "You can write only numbers!"
Any help is welcome :)
Michele71
Comments (7)
Michele Marcelli
WoW! A different way to reach the same conclusion! The previous mode was fine, but this is great!
Anubis Thank you so much! :)
P.S: Your answers are never too late ;)
hello
or...
fn isNumSeq str = ((trimLeft str "0123456789").count == 0)
on edt1 changed txt do
	if not isNumSeq txt do
		messagebox "You can write only numbers!"
uh, maybe i reply too late :)
Michele Marcelli
Ho yes! it is right! :)
Very very thanks!!!!!!!!!
mjbg
this should workon
this should work
try(if superclassof (execute edt1.text) != number do messagebox "You can write only numbers!")
catch(messagebox "You can write only numbers!")
but i really belive using a spinner would be much better
Reply to mjbg
Michele Marcelli
The spinner not good. I'm creating a script calculation ;)
Reply to Michele Marcelli
Oleksandr Kramer
Ctrl+n?
You now about shortcut Ctrl+n?
Reply to Oleksandr Kramer
Michele Marcelli
Course track :)
I am preparing a small script which calculates the mass, density and volume of an object, like a small calculator. I would like to speed up the calculation. The real problem is NOT to write letters in dell'Edittext ;)
Thanks anyway for your suggestion
