Hi. I need some help with replacing a string inside a file.
I need to open an OBJ file and change this mtllib ./occlusion02.mtl into this mtllib occlusion02.mtl , removing the "./"
How can I do that?
By alexmbr · 2007-03-26
How can I do that?
This is my stab at it. I have no idea if this code works at all but it should be a good starting point:
function changeFile file = (
fileHandle = openFile file mode:r
position = skipToString fileHandle "./occlusion02.mtl"
if position == undefined then (
-- This string isn't in the file
close fileHandle
return true
) else (
-- Now you know where the string is in the file, and you can output
-- a copy of the file with the new string in that location
close fileHandle
return true
files = getFiles "c:\\foo\\*.obj"
for f in files do (changeFile f)
So, if I replace that string, everything else will stay unchanged?
Only if an obj file is text and not binary. I don't know if it is or not. You may just want to import it into max and adjust the textures before exporting it again.
Just open the .obj file in a text editor (notepad) and change the line.
I need to do this with maxscript, because I have several hundres of OBJ models.
Anyone?
