The following command works as a toggle to hide or show selection brackets. Is there way to set it to false only? The toggle doesn't work for me in my larger script.
actionMan.executeAction 0 "370" -- Tools: Viewport Selection Show Selection Bracket Toggle
I coudn't find any post unfortunitly that already solved this issue. Hopefully you guys know a way.
Thank you.
Once turned Off this setting should stay off - right?
try this one
but you'll need to replace not disp.ShowSelectionBracketsEnabled with False
