Hiding Statistics panel
By Remy · 2019-04-12
This command:
actionMan.executeAction 0 "40829"
should hide the statistics panel but it is actually a toggle.
I like to set this to false only but i couldn't find a maxscript command?
Do you have any suggestions so i can turn it off?
Thank you.
Remy
for some reason "actionMan.executeAction 0 "40829"" doesn't work anymore.
"max show statistics toggle" toggles it off and on while i want to have it off.
Your code didn't work for me unfortunatly.
Reply to Remy
It works with one small correction:
	local table = for i = 1 to actionMan.numActionTables where (actionMan.getActionTable i).name == "Main UI" do exit with actionMan.getActionTable i
	local checked = for i = 1 to table.numActionItems where (item = table.getActionItem i; item.getMenuText &aiMenuText; aiMenuText == "Show Statistics Toggle") do exit with item.isChecked
	if checked do actionMan.executeAction 0 "40829"
Vojtech Cada
	local checked = for i = 1 to tbl.numActionItems where (item = table.getActionItem i; item.getMenuText &aiMenuText; aiMenuText == "Show Statistics Toggle") do exit with item.isChecked
