hide tab inside render setup dialog
By msdfsdf · 2013-08-08
Hi all
I want to hide some tabs inside the render setup dialog.
whenever I assign new renderer, 3ds max shows extra tabs within the render dialog.
for example if I select V-Ray renderer, then 3ds max loads V-Ray, Indirect illumination and other tabs.
I want to hide all the tabs except Common tab within render setup dialog (at the time of assigning new renderer).
Is it possible using maxscripting? can you give some hints on how to do it?
Thanks & regards
mossin
I think that's not possible but anyway why do you need this?
Thanks for quick reply
I dont want to let any user change rendering settings so thats why i wanted to hide render tabs.
can u suggest any solution?
Thanks & Regards
Mossin
