help with script to hide objects based on rotation
By ismail3d · 2010-12-22
hi there
I don't have much knowledge in scripting, but in my current project i needed
a script that set the object visibility key to 0 when it's rotation more than 86 - I have more than 1043 object by the way :) - anyway ....
I did my 1st ever script - which i think is a crap :) - and one of my friends helped me a little and I reached this stage :
for i in selection do
(slidertime=slidertime+1
r = i.rotation as eulerAngles
if r.x >= 71 then
animButtonState = true
slidertime=slidertime-1
i.visibility = true
i.visibility = false
animButtonState = false
but it didn't work will for me, and I couldn't figure what's wrong .
Graph
this should do
	local r = animationRange
	local sel = selection as array
	for t = r.start.frame to r.end.frame do for o in sel do with animate true at time t o.visibility = (o.transform.rotationpart as eulerangles).x >= 86
btw please use the
[code]
[/code] brackets
Reply to Graph
ismail3d
WOW
all in one line :)
thank you soooooooooooooooooooooooooooooo much .
