Hi everyone!
I'm need some help with a script I'm working on for work. I don't really know how to tackle this since i'm pretty new at Maxscript. I have an array of objects that I would be selecting in a scene. This object count will change depending on how many objects I select. Now I want to randomly assign these selected objects with six different wirecolors (color 0 0 0) (color 145 28 177) (color 28 28 177) (color 88 199 225)(color 26 177 26) and (color 249 252 0). So basically I want object [0] in the array to have color 0 0 0 assign to it and so on until it hits the last color then it would repeat. So object 7 in my selection would have color 0 0 0 as well. Is this even doable? I know Max has a random function but it assigns the objects a color value from two sets of RGB values which is not what I want. If anyone has any suggestions it would be greatly appreciated.
Thanks!
Dan Hernandez
Hi Anubis,
Thanks for the quick response. Your script didn't hit the nail directly but it did give me enough info to get what I needed. In the end I ended up with this code block that is attached to this message. Thanks so much for your help! Without your suggestion I would have never been able to get it right.
Cheers!
Dan Hernandez
if i see, something like...
