Im using 3ds max
basically i have alot of boxes as one object and i want to select only the sides and not the top and bottom in edit poly. i also need to be able to select only the tops so either one would help then i can just use invert selection for the others i guess.
if anyone can point me towards a script or anything that can help me with creating one thx in advance.
help selecting only vertical faces in scene or object
By thp777 · 2010-12-23
Comments (7)
as long as it works ;)
couldve done that yourself
that rlly is a simple modification you couldve done yourself quickly ;)
Thanks ! :-)
Don't forget that nothing is really simple for me !
I tried the script and something strange : to select same orientation face u must have a "0.1" value : "0" don't select all faces that it should !....
wow
That worked perfectly.
Thank you so much.
would have taken me forever to figure that out.
Thanks again.
test it on a sphere ;) (
ohhh ! It would be great if you could make a script to select all faces oriented like the selected face modulo a value that we can specify... It would be very helpfull ! :-)
