Help select object
By Kevin · 2013-10-28
Good evening, I'm trying to put a personal selection shortly after instance to understand that the script is the selected object. How can I do this?
local objPos = (intersectRay $ground treeRay).pos,
objScale = [1,1,1] * random fromScale.value toScale.value
instance ?????????? pos:objPos scale:objScale name:"Objeto copia"
Kevin
Staff will try to explain again.
In my intance if I leave it at $'ll be picking up my box Box I want to create an object that understands that the object I want is selected. How can I do this?
instance $box pos:objPos scale:objScale name:"Objeto copia
Reply to Kevin
If I understand you correctly you want to create an instance of currently selected object. In this case use this:
	if selection.count != 0 then
		selObjsArr = selection as array
		instancesArr = for o in selObjsArr collect
			instance o pos:(o.pos + [100,100,100]) isSelected:true
		--	select created instances
		select instancesArr
		messagebox "Select at least one object" title:"Empty Selection"
Code works with multiple objects that are selected. instancesArr holds all created instances, so you can select them with select instancesArr.
I don't understand exactly what you want to acheive, but
1 - if you want to create an instance of some object and you want this instance to be selected after it is created then use this
newObj = instance $teapot001 pos:[100,100,100] isSelected:true
The Teapot001 is the object that will be instanced.
isSelected:true
will select the created instance
newObj
will hold the created instance, so later you can use neObj to access any of the properties of the created instance.
