I'm trying to script a parenting function within a larger script but having trouble.
I've found that when the names are predetermined this works fine:
$.parent = $Sphere001_ROOT
(Sphere001 is Selected, Sphere001_Root is a point helper)
However the names change from object to object. What I'm hoping to get working is proper syntax for the following:
tempobj = $
--start object is collected at start when object is selected
tempdummy = $
--dummy object is collected at when dummy is created
tempobj.parent = tempdummy
I guess the basic form of the question is how to parent objects without using the object name.
Any help would be appreciated.
If you selection is with proper order then you will know which object to wjich dummy will be linked. I mean that the code below uses selection order.
That's perfect, thanks very much!
I'm very poor at scripting but you helped me make my job that little bit easier.
Glad to help. :)
