When sending a job to the backburner with region on,
max will say:"you are about to send...." warning you that your
region is on.
I`m trying doing the same with the render region on Vray frame buffer.
so far i wrote the basic warning:
if vrayVFBGetRegionEnabled() then messageBox "VFB Region is On!!"
How can i execute it when the user do this(sending a job to the backburner)
macros.run "Render" "RenderButtonMenu_Submit_to_Network_Rendering"
Callbacks
So...after a little diging,i think #callback is the
way to do this.
any one know the callBack code for "Submit to Network Rendering"
operation?
