Help needed with Spline to XML script
By Manfred Gebhard · 2014-03-04
I'm actually working on a script which should export several splines to XML so a game (Shogun 2) can use it.
Since I'm a total Newbie regarding maxscript - everything I know was learned today by trial and error with a script I've found which already exports splines to xml but It would need some modifications.
- what it should do -
I need the script for exporting splines to a format which the game Shogun 2 is using (for a mod). Soldiers are using those splines as guide where to stand within buildings. Therefore some information are need like position of the knots, which type (in my example "low wall") and in which direction the spline is "facing"
- what my script actually does -
At the moment I select one spline, run the script and in the Listener I type exportasxml ("example.xml") which then gives me the file. But the script would have to write few hundred entries. Which code do I have to write that I can export severel selected splines at once?
Next thing:
-- what type the EF line is
		for i= 1 to k do
Because of this my script actually loops through all knots of a spline (which are only two) and so it writes two identical entries.
I tried
for i= 1 to $.count
so it instead loops through the selected splines and writes one entry for each spline, but atm it doesn't work.
Another question would be, if it's possible to get the "direction" in which a spline is facing?
Here an example what I actually get by using the code and how it should look like:
http://i304.photobucket.com/albums/nn166/Primergy/erklaumlrung_zps39517b…
And here's the script for a quick look:
global theFileStream
fn printToFile theString t:0 =
  -- auto tab (empty string)
  tabString = " ";
  tabString = substring tabString 1 (t*4);
  -- print
  format "%%\n" tabString theString to:theFileStream;
fn exportAsXML fileName =
  theFileStream = createFile fileName;
  -- ok to write?
  if theFileStream != undefined then
    -- reference to selected shape
	s     = selection[1]
	k     = numKnots s
	knots = k as String
	cl    = isClosed s 1 as String
	-- open
	printToFile ("<building_logic>")
	-- building defence type
	printToFile	("<building_defence_type>open</building_defence_type>")
	-- EF_lines
	printToFile ("<ef_lines>")
		for i= 1 to k do
		local actiontype =  getUserPropBuffer $
    -- root node
		printToFile ("<ef_line name='"+ s.name +"' action=' "+ actiontype +"'>")
		for i= 1 to k do
		(knot = getKnotPoint s 1 i
	  x    = knot.x as String
	  y    = knot.y as String
	  z    = knot.z as String
			printToFile ("<end x='" + x +"'y='"+ y +"'z='"+ z +"'/>")
			printToFile ("<direction x='" + knots + "' y='" + knots + "' z='" + knots + "'/>")
		printToFile ("</ef_line>")
	-- ef_lines close
	printToFile ("</ef_lines>")
	--write artillery
	printToFile ("<ef_artillery_info>")
	--close artillery
	PrintToFile ("</ef_artillery_info>")
	-- close
    printToFile ("</building_logic>")
  close theFileStream;
