Hi, I'm new to Maxscript and want to make a script in which creates multiply custom object(s) like 4 long cylinders with a box ontop and grouped, then allows you to align those objects to a line you draw and then duplicate that object at certain levels above the previous group of objects.
Imagine if you will a custom object like a stone wall shape which you just pressed a button and it follows a line you build...like path deform and then duplicates it higher with a click.
Any advice or scripts similar I can learn off would be nice also.
Thanks.
try visit this, if you want to create custom object
http://www.scriptspot.com/3ds-max/scripts/cirpyramid
try obj to spline
I tried that and did get some useful code from it Thanks!.
Any idea how I can create a custom object and store its information so I can press a button and it will place the object along the line I've created???
